Based on REST principles, the TrendMiner Work Organizer API endpoints provide access to all work created and saved by users like views, searches, formulas, etc.
1. Authentication
Requests to the Work Organizer API can be done authenticated as your client. To do requests, you first need to create a client and request a token.
When you create/update saved items authenticated as your client, they will belong to service-account-CLIENTID.
1.1. Creating a new client
Your client ID
curl --request POST \
200 OK
"expires_in": 300,
"refresh_expires_in": 0,
"token_type": "Bearer",
"scope": "email profile"
1.3. Doing a request with an access token
curl --request GET \
--url 'https://YOUR_DOMAIN/work/[any-api]' \
2. Resources
2.1. AccessRules
2.1.1. Create an access rule for the saved item.
POST /saveditem/{savedItemId}/accessrule
Parameters
Type |
Name |
Description |
Schema |
Path required |
savedItemId |
The saved item for which to create the access rule |
String |
Body required |
SavedItemAccessRuleModel |
The access rule model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
AccessRuleResource |
404 |
The resource was not found |
201 |
Created |
400 |
Validation failed |
Produces
application/json
2.1.2. Delete an access rule for a saved item
DELETE /saveditem/{savedItemId}/accessrule/{accessRuleId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
savedItemId |
The saved item to which the access rule apply |
String |
Path required |
accessRuleId |
The identifier of the access rule to delete |
UUID |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
404 |
String |
204 |
No response |
String |
400 |
Validation failed |
String |
Produces
application/json
2.1.3. Get the access rules for a saved item.
GET /saveditem/{savedItemId}/accessrule
Parameters
Type |
Name |
Description |
Schema |
Path required |
savedItemId |
The saved item to which the access rules apply |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
List[AccessRuleResource] |
404 |
400 |
Validation failed |
200 |
OK |
Produces
application/json
2.2. Permissions
2.2.1. Returns a list of permissions for the saved item for the current logged in user
GET /permissions
Parameters
Type |
Name |
Description |
Schema |
Query optional |
saved-item-identifier |
The identifier of the saved item to fetch permissions.This can be omitted for complex-item-identifier. |
Query optional |
complex-item-identifier |
The external identifier of the complex item to fetch permissions. This will be ignored if saved-item-identifier is present. |
Responses
HTTP Code |
Description |
Schema |
403 |
Forbidden |
PermissionsResource |
200 |
Ok |
404 |
Resource not found |
Produces
application/json
2.3. Preferences
2.3.1. Create a new preference
POST /preferences
Parameters
Type |
Name |
Description |
Schema |
Body required |
PreferenceModel |
A representation of a preference with name and data to create |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PreferenceResource |
201 |
Created |
400 |
Validation failed |
Produces
application/json
2.3.2. Delete an existing preference for the logged in user
DELETE /preferences/{name}
Parameters
Type |
Name |
Description |
Schema |
Path required |
name |
The name of an existing preference to delete |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
404 |
Resource(s) not found! |
String |
405 |
Method Not Allowed |
String |
204 |
No response |
String |
400 |
Validation failed |
String |
Produces
application/json
2.3.3. Retrieve an existing preference for the logged in user
GET /preferences/{name}
Parameters
Type |
Name |
Description |
Schema |
Path required |
name |
The name of an existing preference to retrieve |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
404 |
200 |
Ok |
Produces
application/json
2.3.4. Retrieve all preferences for the logged in user
GET /preferences
Parameters
| Type | Name | Description | Schema |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
List[PreferenceResource] |
200 |
Ok |
Produces
application/json
2.3.5. Store a list of preferences
POST /preferences/store
Parameters
Type |
Name |
Description |
Schema |
Body required |
PreferenceModel |
A list of preferences to store |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
400 |
Validation failed |
200 |
Ok |
Produces
application/json
2.3.6. Update a preference
PUT /preferences/{name}
Parameters
Type |
Name |
Description |
Schema |
Path required |
name |
The name of an existing preference to update |
String |
Body required |
PreferenceModel |
A representation of a preference with data to update.<br> The name in this model will be ignored. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
404 |
405 |
400 |
Validation failed |
200 |
Ok |
Produces
application/json
2.4. SavedItemTypes
2.4.1. Retrieves the details of the specified type
GET /saveditemtype/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The name of the saved item type to retrieve details of |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
SavedItemTypeResource |
Produces
application/hal+json
application/x-spring-data-compact+json
2.4.2. List all the available saved item types
GET /saveditemtype
Parameters
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
CollectionModelSavedItemTypeResource |
Produces
2.5. SavedItems
2.5.1. Browse the contents of a folder
GET /saveditem/browse
Parameters
Type |
Name |
Description |
Schema |
Query optional |
parent |
The identifier of the folder you want to browse |
Query optional |
excludeTypes |
A list of saved item types.<br/>These types will be excluded from the result. |
Query optional |
includeTypes |
A list of saved item types.<br/>The result will only contain these types. |
Query optional |
includeData |
Set to true to include the full data object in the result.<br/>Defaults to false |
Query optional |
foldersOnly |
Set to true to only return folders. |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Sorting criteria in the format: property(,asc |
Responses
HTTP Code |
Description |
Schema |
404 |
The resource was not found! |
PagedModelSavedItemResource |
400 |
Validation failed |
200 |
Ok |
Produces
2.5.2. Copy an existing saved item.
POST /saveditem/{id}/copy
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the existing saved item that will be copied |
String |
Body required |
SavedItemModel |
The API model containing the changes to apply to the copied saved item.<br/>Only the name and/or description can be changed |
Responses
HTTP Code |
Description |
Schema |
403 |
Forbidden |
SavedItemResource |
404 |
SavedItemResource |
201 |
Created |
SavedItemResource |
400 |
Validation failed |
SavedItemResource |
Produces
2.5.3. Create a new saved item
POST /saveditem
Parameters
Type |
Name |
Description |
Schema |
Body required |
SavedItemModel |
A model of the item to create |
Responses
HTTP Code |
Description |
Schema |
201 |
Created |
SavedItemResource |
400 |
Validation failed |
SavedItemResource |
Produces
2.5.4. Delete saved item(s)
DELETE /saveditem/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The id's of the saved items to delete |
String |
Responses
HTTP Code |
Description |
Schema |
404 |
DeletedItemsResource |
200 |
OK |
Produces
2.5.5. Retrieve a saved item
GET /saveditem/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the saved item to retrieve.<br/>This identifier should be a valid UUID. |
String |
Responses
HTTP Code |
Description |
Schema |
404 |
SavedItemResource |
403 |
Forbidden |
SavedItemResource |
200 |
Ok |
SavedItemResource |
Produces
2.5.6. Move saved item(s) to a folder
PUT /saveditem/{id}/move
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
List |
Path required |
itemsToMove |
The identifier(s) of the saved item(s) to move. |
String |
Query optional |
destination |
The identifier of the destination folder. |
Responses
HTTP Code |
Description |
Schema |
204 |
Ok |
Object |
404 |
Object |
406 |
Duplicate item! |
Folder structure invalid! |
Produces
2.5.7. Patch a saved item
PATCH /saveditem/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the saved item that will be patched |
String |
Body required |
SavedItemModel |
The API model containing the changes to apply to the saved item. Only the extended view properties are checked and the rest will be ignored |
Responses
HTTP Code |
Description |
Schema |
404 |
SavedItemResource |
400 |
Validation failed |
SavedItemResource |
200 |
Ok |
SavedItemResource |
406 |
Duplicate item! |
Produces
2.5.8. Search saved items
GET /saveditem/search
Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
A query string to search.<br/>Only the name and description of the saved item are search.<br/>Wildcards (*) are supported on all locations. |
Query optional |
excludeTypes |
Query optional |
includeTypes |
Query optional |
includeData |
Query optional |
sharedWithMe |
Set to true to filter the results to only show items that are shared with the logged in user.<br/>Defaults to false |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
400 |
Validation failed |
200 |
Ok |
Produces
2.5.9. Update a saved item
PUT /saveditem/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the saved item that will be updated |
String |
Body required |
SavedItemModel |
The API model containing the changes to apply to the saved item. |
Responses
HTTP Code |
Description |
Schema |
404 |
SavedItemResource |
400 |
Validation failed |
SavedItemResource |
200 |
Ok |
SavedItemResource |
406 |
Duplicate item! |
Produces
2.6. SavedItemsDemo
2.6.1. Create demo saved items for a (new) user
POST /saveditem/demo
Parameters
Type |
Name |
Description |
Schema |
Body required |
UserInformationModel |
Responses
HTTP Code |
Description |
Schema |
201 |
Created |
Object |
400 |
Validation failed |
Object |
Produces
2.7. SavedItemsExportImport
2.7.1. Export saved items
GET /export
Parameters
Type |
Name |
Description |
Schema |
Query optional |
username |
The username for which the savedItems need to be exported (default: current user) |
Responses
HTTP Code |
Description |
Schema |
403 |
Forbidden |
Object |
200 |
Ok |
Object |
Produces
2.7.2. Retrieve the results from the current or last import
GET /import/result
Parameters
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ImportResult |
Produces
2.7.3. Import saved items
POST /import
Parameters
Type |
Name |
Description |
Schema |
Query optional |
username |
The username for which the savedItems need to be imported (default: current user) |
Query optional |
skip |
when set to true, duplicates will not be imported; when set to false, duplicates will be replaced (default: true) |
Responses
HTTP Code |
Description |
Schema |
403 |
Forbidden |
ImportResult |
200 |
Ok |
ImportResult |
Produces
2.8. Sessions
2.8.1. Create a new session
POST /sessions
Parameters
Type |
Name |
Description |
Schema |
Body required |
SessionModel |
A session containing valid JSON data |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
201 |
Created |
400 |
Validation failed |
Produces
application/json
2.8.2. Delete an existing session
DELETE /sessions/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The short url identifier of the session to delete |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Object |
404 |
Object |
405 |
Object |
204 |
No response |
Object |
400 |
Validation failed |
Object |
Produces
application/json
2.8.3. Retrieve a session
GET /sessions/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The short url identifier of the session to retrieve |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
404 |
200 |
Ok |
Produces
application/json
2.8.4. Get a session by viewId
GET /sessions
Parameters
Type |
Name |
Description |
Schema |
Query required |
viewId |
The viewId of the session |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
404 |
200 |
Ok |
Produces
application/json
3. Models
3.1. AccessRuleResource
Represents an access rule definition
| Field Name | Required | Type | Description | Format |
identifier |
String |
The identifier of the access rule. |
objectId |
X |
String |
The identifier of the object. |
paths |
X |
List of [string] |
An array of paths towards the object. |
subjectId |
X |
String |
The identifier of the subject. |
subjectType |
X |
String |
The type of the subject: USER, GROUP, EVERYBODY, GUEST. |
Enum: GUEST, EVERYONE, GROUP, USER, |
permissions |
X |
Set of [string] |
A set of permissions the subject has on the specified object. Can be an empty set. |
Enum: |
userDetailsResource |
UserDetailsResource |
_links |
Map of Link |
3.2. CollectionModelSavedItemTypeResource
_embedded |
CollectionModelSavedItemTypeResource__embedded |
_links |
Map of Link |
3.3. CollectionModelSavedItemTypeResourceEmbedded
savedItemTypeResourceList |
List of SavedItemTypeResource |
3.4. DeletedItemsResource
Object to describe the saved items that were deleted
identifiers |
List of [string] |
The identifiers of the deleted items |
_links |
Map of Link |
3.5. ImportFailure
fileLocation |
String |
typeOfFailure |
String |
message |
String |
itemIdentifier |
String |
itemName |
String |
itemType |
String |
itemLocation |
List of [string] |
3.6. ImportResult
identifier |
UUID |
uuid |
inProgress |
Boolean |
startTime |
String |
endTime |
String |
severeFailure |
ImportFailure |
totalOfItemsSuccessfullyImported |
Integer |
int32 |
totalOfItemsFailedToImport |
Integer |
int32 |
totalOfSkippedItems |
Integer |
int32 |
totalOfReplacedItems |
Integer |
int32 |
failureDetails |
List of ImportFailure |
itemsSkipped |
List of [string] |
itemsReplaced |
List of [string] |
3.7. Link
href |
String |
hreflang |
String |
title |
String |
type |
String |
deprecation |
String |
profile |
String |
name |
String |
templated |
Boolean |
3.8. PageMetadata
size |
Long |
int64 |
totalElements |
Long |
int64 |
totalPages |
Long |
int64 |
number |
Long |
int64 |
3.9. PagedModelSavedItemResource
_embedded |
PagedModelSavedItemResource__embedded |
_links |
Map of Link |
page |
PageMetadata |
3.10. PagedModelSavedItemResourceEmbedded
content |
List of SavedItemResource |
3.11. PermissionsResource
Describes a list of permissions
permissions |
List of [string] |
The list of permissions |
_links |
Map of Link |
3.12. PreferenceModel
API model of a preference
name |
X |
String |
A unique name for the preference |
data |
X |
Object |
JSON object containing the definition of the preference |
3.13. PreferenceResource
Represents a saved user preference
name |
String |
The name of the preference |
data |
Object |
_links |
Map of Link |
3.14. SavedItemAccessRuleModel
API model for an access rule on a SavedItem
subjectId |
String |
The identifier of the subject for which to grant the access rule |
subjectType |
X |
String |
The type of the subject |
permissions |
X |
Set of [string] |
The set of permissions |
Enum: |
autoGenerated |
Boolean |
3.15. SavedItemModel
API model for creation or modification of a saved item
id |
String |
The identifier of the saved item.<br/>This identifier is a UUID. |
parentId |
String |
The UUID of the folder where this saved item can be found.<br/>This folder is a saved item.<br/>When empty, the saved item will be saved in the most top level. |
type |
String |
The type of the saved item.<br/>The type indicates what can be stored in the data property. |
Enum: SIMILARITY_SEARCH, VALUE_BASED_SEARCH, CROSS_ASSET_VALUE_BASED_SEARCH, DIGITAL_STEP_SEARCH, AREA_SEARCH, FINGERPRINT, LEGACY_FINGERPRINT, VIEW, TREND_HUB_2_VIEW, FILTER, CONTEXT_LOGBOOK_VIEW, FORMULA, AGGREGATION, DASHBOARD, MONITOR, MACHINE_LEARNING, PREDICTIVE, TOTALIZER, NOTEBOOK, PIPELINE, |
name |
X |
String |
The name of the savedItem |
description |
String |
The description of the savedItem |
data |
Map of [object] |
A Json Object representing the content of the saved item.<br/>This content is specific to the saved item type. |
extendedViewProperties |
Map of [string] |
Key value pairs representing the extended view properties of the saved item.<br/>This content is specific to the saved item type. |
folder |
Boolean |
true if the saved item is a folder; false otherwise.<br/>A folder can not contain data nor a type.<br/>As a result, both the data and type property will be ignored when a folder is saved. |
3.16. SavedItemResource
The definition of a saved item
identifier |
String |
type |
String |
name |
String |
The name of the saved item. |
description |
String |
The description of the saved item. |
data |
Map of [object] |
A Json Object representing the content of the saved item.<br/>This content is specific to the saved item type.<br/>The data is, by default, only available when retrieving a single saved item.<br/>This behaviour can be overridden in lists by explicitly providing "includeData" in the request URL. |
Map of [string] |
lastModifiedDate |
Date |
The UTC date when the saved item was last modified. |
date-time |
folder |
Boolean |
true if the saved item is a folder; false otherwise. |
shared |
Boolean |
true if the saved item is shared; false otherwise. |
owner |
String |
The name of the saved item's owner. |
ownerUuid |
String |
The UUID of the saved item's owner. |
ownerUserDetails |
parentId |
String |
The UUID of the folder where this saved item can be found.<br/>This folder is a saved item. |
permissions |
Set of [string] |
A list of permissions on the saved item for the current logged in user.<br/>Possible permissions:<br/>* SAVED_ITEM_NO_PERMISSIONS - The item can not be accessed;<br/>* SAVED_ITEM_READ_ITEM - The item can be read;<br/>* SAVED_ITEM_WRITE_ITEM - The item can be updated. |
_links |
Map of Link |
3.17. SavedItemTypeResource
Represents a SavedItemType definition
name |
String |
description |
String |
category |
String |
_links |
Map of Link |
3.18. SessionModel
API model of a session
data |
X |
Object |
3.19. UserDetailsResource
Details about a user
userId |
String |
Unique identifier |
userName |
String |
Username |
firstName |
String |
First name |
lastName |
String |
Last name |
3.20. UserInformationModel
userUuid |
String |
The uuid of the owner of the new demo tag |
