Based on simple REST principles, the TrendMiner Context API endpoints return JSON metadata about context items, types, and other related objects in the TrendMiner platform.
1. Introduction
1.1. Infrastructure
Context can be pulled into the TrendMiner platform through multiple pathways. One is the REST API described in the developer documentation here. The other is by hooking TrendMiner to your iPaas system.
ContextHub supports the contextualization of tags, assets and attributes, or, components as we call them in general. All information is contained within an entity called a context item. Which makes the /item endpoint the main endpoint to create and search for context in the platform.
1.2. Requests
The TrendMiner Web API is based on REST principles. Data resources are accessed via standard HTTPS requests in UTF-8 format to an API endpoint. Where possible, the web API uses appropriate HTTP verbs for each action:
| Method | Action |
GET |
Retrieves resources |
POST |
Creates resources |
PUT |
Changes and/or replaces resources or collections |
DELETE |
Deletes resources |
1.3. Responses
The web API returns all response data as a JSON object. Have a look at the definitions for a description of all retrievable objects.
1.4. Timestamps
Timestamps are returned in ISO 8601 format as Coordinated Universal Time (UTC) with a zero offset: YYYY-MM-DDTHH:MM:SSZ.
2. Authentication
When performing actions authenticated as a client, they will belong to service-account-CLIENTID.
2.1. Creating a new client
2.2. Retrieving an access token
Your client ID
curl --request POST \
200 OK
"expires_in": 300,
"refresh_expires_in": 0,
"token_type": "Bearer",
"scope": "email profile"
2.3. Doing a request with an access token
curl --request GET \
--url 'https://YOUR_DOMAIN/context/item/d0a58479-4120-4683-a143-42f5e7ac249e' \
3. Creating context items
Creating context items can be done in two distinct ways:
using the Context Item API, to create an item, its events and its component in one request,
using the Context Data API, to create an item, while additional requests to other APIs are needed for events and component.
This section will focus on the first, and will explain the necessary parts needed to fire your request.
To create a context item, three mandatory parts need to be provided:
the type of the context item, which needs to exist up front,
at least one event, which is defined by the used type,
a component on which this item occurs.
3.1. Mandatory information
3.1.1. Type and workflows
A type indicates what kind of context item we’re dealing with. To create a context item, the type already needs to exist. It can be created using the type API or using ContextHub.
Every type can be assigned a workflow. A workflow dictates the different phases a context item of a certain type can go through, from start to completion.
In case a context item is created using a type that is not assigned a workflow, the context item will be considered instantaneous and can only have one stateless event.
By default, TrendMiner has a few predefined types and workflow. Examples are
ANOMALYwith statesStartedandEnded, -
INFORMATIONwithout workflow, -
OPERATIONALwith statesIn progress,Paused, andEnded.
3.1.2. Events
An event is the occurrence of a notable thing — event, action, incident, … — and refers to a specific point in time.
In case the type of the context item is assigned a workflow, the events on the context item need to have a state. In this case, the earliest occurring event’s state must be the start event, as defined in the workflow. When assigning an event state which is the workflow’s end state, this event must reflect the latest time the workflow operates.
Regardless of the type, an event needs to be sent.
3.1.3. Component
A component is the reference to a tag, asset or attribute. Since context items are all about contextualizing these, a component is mandatory.
Because tags or assets and attributes are not part of the context domain, we need identify them within their own respective domains.
Tags
Tags are mainly used when there is no asset framework available to structure tags in a logical tree. The identifier to be used during context item creation is the name of the tag.
Assets & attributes
Assets and attributes are used to create a logical structure. While an asset is purely a virtual concept, an attribute will internally link to a tag.
Assets can be found using the Assets API. The identifier to be used during context item creation is the nodeId.
3.2. Additional information
Besides the mandatory parts for creating context items, additional information can be added to the item to provide more details.
A description can be used to give more information on the event. Any text can be written here. Next to a description, keywords and additional fields can be provided as well.
3.2.1. Keywords
Keywords are used to make searching on context items easier.
Context items can contain as many keywords as needed, as long as they are shorter than 100 characters and do not contain commas.
3.2.2. Fields & other properties
Fields and properties can contain any data to further describe a context item. While their purpose is the same, there is a small distinction.
Fields are properties with a predefined data type. A field’s type can be either STRING, NUMERIC or ENUMERATION. The latter can have predefined values. More advanced searching capabilities are available when using fields.
Fields are created independently of context item types, and are linked to them through ContextHub. In ContextHub, when creating or editing context items, fields can be modified as well. To find out which fields are used on a type, use the Type API.
Other properties are properties without a predefined data type. When present on a context item, they will be shown in ContextHub. They are however not editable through ContextHub, only through the API.
Both fields and other properties need to be filled in the fields part of the request body in a "key": "value" manner.
3.3. Examples
All these parts need to be combined to create a new context item. For detailed information, refer to the Context Item API or the Context Data API.
Tip
For more detailed information on building context items without using the context item API, see Context Data API, Context Data Event API and Context Data Reference API. |
POST https://trendminer.company.net/context/item HTTP/1.1
Content-Type: application/json
"description": "Elevated temperature detected",
"keywords": [
"temperature"
"type": {
"identifier": "ANOMALY"
"components": [
"type": "TAG",
"reference": "BA:LEVEL.1"
"fields": {
"criticality": "HIGH",
"temperature": 87.2
"events": [
"state": "Started",
"occurred": "2019-11-14T08:31:58.000Z"
"type": {
"identifier": "INFORMATION"
"components": [
"type": "ASSET",
"reference": "8397fef9-ad29-4ee5-bf04-72a11c0b233c"
"events": [
"occurred": "2019-11-13T13:55:07.000Z"
4. Context item search
Context items can be searched using the API’s paged search endpoint. The search endpoint will always need at least one filter to limit the timeframe to look at.
4.1. Version 1
Warning
Version 1 of the search endpoint is deprecated. Please use version 2. |
The version 1 search endpoint is a paged API. The response will include a metadata block with the current page information.
POST /context/item/search?page=0&size=20
"filters": {
"periodType": "LAST_EIGHT_HOURS",
"period": "PT8H",
"live": false,
"type": "PERIOD_FILTER"
"type": "COMPONENT_FILTER"
"components": [
"identifier": "e56b9148-b109-4495-9e84-9cbf866201bc",
"type": "ASSET",
"path": "e56b9148b10944959e849cbf866201bc",
"include": "SELF"
"links": [...],
"content": [
"permissions": [
"ASSET_READ_CONTEXT_ITEM"
"identifier": "de04ed72-f135-400a-bc11-65104e8c7998",
"shortKey": "901-C6",
"externalId": "dc165337-5e6e-11ec-8a12-000d3ac26207",
"description": "Something happened here.",
"events": [
"identifier": "1d4f153e-3342-4c1a-ac47-6deed0152422",
"occurred": "2021-12-16T12:51:00Z",
"state": "Started",
"links": [...]
"lastModifiedDate": "2022-05-09T02:00:03.454513Z",
"createdBy": "833af9d7-b2fc-40a6-bb38-08a5d2ced6ca",
"createdDate": "2021-12-16T12:54:29.640088Z",
"userDetails": {
"identifier": "833af9d7-b2fc-40a6-bb38-08a5d2ced6ca",
"username": "service-account-tm-context"
"components": [],
"type": {
"identifier": "6e77cfbc876f4b4aae8ec2372f7bdd0f",
"name": "PI Event Frame",
"color": "4A75E2",
"icon": "flow--line"
"workFlowDescribed": true,
"fields": {
"tm_EF_SYNC_MISSING_DATA_REFERENCE": true,
"tm_EF_SYNC_MISSING_DATA_REFERENCE_RETRIES": 130,
"EVENT_FRAME_NAME": "EF20211216-001"
"keywords": [],
"startEventDate": "2021-12-16T12:51:00Z",
"lastEventState": "Started",
"totalDuration": "PT3450H54M32S",
"links": [...]
"page": {
"size": 20,
"totalElements": 697,
"totalPages": 35,
"number": 0
4.2. Version 2
The newly available version 2 search endpoint works token based and has improved performance compared to version 1.
The request format looks more or less the same, as at least one time-based filter is still required. Next to the list of filters, an optional continuation token will need to be provided in the request. This continuation token will be generated and is present on the previous response.
POST /context/v2/item/search
"filters": [
"type": "PERIOD_FILTER",
"valid": true,
"period": "PT8H",
"live": false
"sortDirection": "desc",
"sortProperties": [
"startEventDate"
"fetchSize": 60,
"continuationToken": "eyJzb3J0RGlyZWN0aW9uIjoiZGVzYyIsInByb3BlcnR5RGF0YU1hcCI6eyJzdGFydEV2ZW50RGF0ZSI6IjIwMjItMDUtMDlUMDY6MzU6MDJaIiwic2hvcnRLZXkiOiJDM0EtQTQifX0="
"content": [
"permissions": [
"events": [
"state": "Started",
"links": [...]
"userDetails": {
"components": [],
"type": {
"color": "4A75E2",
"fields": {
"keywords": [],
"links": [...]
"page": {
4.3. Available filters
In current release, available filters to use are:
the period and interval filters
the type filter
the component filter
the description filter
the keyword filter
the created by filter
the custom field or other property filter
the approvals filter
the duration filter
the current state filter
Each of these filters require their own input data.
To specify a more precise search query, the filters can be combined. Combining filters will return only those context items that match the criteria of every specified filter.
4.4. Period and interval filter
The period filter creates a moving window of time, starting from the current time, and going back a predefined portion of time.
Key |
Description |
1 hour |
2 hours |
8 hours |
1 day |
7 days |
28 days |
When using the period filter, one also has the option to have item be sent back as they are created. To do so, the live flag needs to be set.
"live": false
Alternatively, when searching for a pre-defined time frame, the interval filter can be used to specify the range, using start and end date. Use the ISO date format in UTC timezone to specify the dates.
"type": "INTERVAL_FILTER",
"startDate": "2019-08-01T22:00:00.000Z",
"endDate": "2019-08-02T21:59:00.000Z"
4.5. Type filter
The type filter can be used to return only those context items of the specified types. The filter accepts a list of type identifiers.
"type": "TYPE_FILTER",
"types": [
"ANOMALY",
"INFORMATION"
4.6. Component filter
The component filter is used to limit the results to context items linked to a certain asset, attribute or tag. Multiple components can be specified.
When searching for tags, the identifier to specify is the tag’s name or its UUID. The UUID can be found from querying tm-datasource timeseries API.
For assets and attributes, it is also possible to search for context items linked to certain assets or attributes, or any of the components in the tree above the specified one. When doing so, specifying the path to the current asset or attribute is required. This path can be found on the structure resource of the node. Check out the Assets API for more information on structures, nodes and paths.
When searching for context items created on specific assets or attributes, it is sufficient to provide the nodeId. However, it is also possible to search for context items that are created on the parents or children of an asset or attribute. To do this, we need to provide the filter with the path information and the relative type. This path can be found on the node resource. Check out the Assets API for more information on nodes and paths
SELF: Only include the node. DEFAULT
ANCESTORS: Include context items created on the node and on its parents. PATH is required
DESCENDANTS: Include context items created on the node and on all of its children. PATH is required
"type": "COMPONENT_FILTER",
"components": [
"identifier": "51f0d710-246f-4a89-9264-25df45df53e0",
"type": "ATTRIBUTE",
"path": "64dc37890dd147629bd1151a6b0729cd.51f0d710246f4a89926425df45df53e0",
"include": "DESCENDANTS"
4.7. Description filter
Searching for certain words or phrases in the description of context items is possible using the description filter. The filter allows for specifying multiple words to look for. Wildcards can be used as well: an asterisk (*) will match zero to any range of characters.
"type": "DESCRIPTION_FILTER",
"values": [
"clogged",
"phase *.b"
4.8. Keyword filter
Upon creating of a context item, keywords can be specified. Using the keyword filter, searching can be limitted to items having the provided keywords. Multiple keywords can be specified.
"type": "KEYWORD_FILTER",
"keywords": [
"overflow"
4.9. Created by filter
Using the created by filter, only context items created by the specified users are returned. Multiple users can be specified.
To specify the users, use their identifiers.
"type": "CREATED_BY_FILTER",
"users": [
"ea02ab87-ebbf-4f7b-af6d-8dffd819abe0"
4.10. Custom field and other property filter
As there are three different types of custom field, there are also three different types of custom field filter: numeric, string and enumeration. The custom field filter can only be used on existing custom fields. The value for field needs to be the identifier of the custom field. Specifying a custom field that does not exist will result in an error.
4.10.1. Numeric field filter
The numeric field filter searches for context items having the specified custom field filled in with a number matching the specified criteria. These criteria are simple mathematical conditions:
Operator |
Description |
item value = specified value |
item value != specified value |
item value < specified value |
item value ≤ specified value |
item value > specified value |
item value ≥ specified value |
One can specify up to two conditions.
"type": "NUMERIC_FIELD_FILTER",
"field": "loss_value",
"conditions": [
"operator": "GREATER_THAN_OR_EQUAL",
"value": 12
4.10.2. String field filter
The string field filter searches for context items having the specified custom field filled in with a string value matching the specified value. String matching is done in the same way as the description filter. Multiple values can be specified.
"type": "STRING_FIELD_FILTER",
"field": "client",
"values": [
"Trend*"
4.10.3. Enumeration field filter
The enumeration field filter searches for context items having the specified custom field filled in with the one of the specified values. These values need to be present in the custom field’s definition. Specifying a value that does not exist in the custom field definition will result in error.
"type": "ENUMERATION_FIELD_FILTER",
"field": "cause",
"values":[
"Human error",
"Late maintenance"
4.10.4. Other property filter
Other properties on a context item can be present when a sync puts them there or when using the API. These properties can have names or values not defined as custom field. To search on these properties, the other properties filter can be used. This filter will perform string matches in the same way as the description filter. Multiple values can be specified.
The key to specify is the actual property’s name.
"type": "PROPERTY_FIELD_FILTER",
"key": "color",
"values":[
"brown",
"green"
4.11. Approval filter
When approvals are enabled on context item types, users can mark a context item as approved to demonstrate acknowledgement. Using the approval filter, we can specify if we want to see context items either approved or not.
"type": "APPROVAL_FILTER",
"withApprovals": false
4.12. Duration filter
Context items with types that are assigned a workflow have a duration. The duration is calculated from initiation of the start event until the occurrence of an end event, or, in case there is none yet, until now. Using the duration filter, we can apply a simple mathematical operator when searching for context items that have a duration. See also Condition operators.
Duration is provided in standard ISO Duration format
"type": "DURATION_FILTER",
"conditions": [
"operator": "GREATER_THAN",
"value": "PT1H30M"
4.13. Current state filter
Context items with types that are assigned a workflow, are locked into a specific state at any time. Using the current state filter, we can search for context items of any specified state.
"type": "CURRENT_STATE_FILTER",
"states": [
"In progress"
4.14. Combining filters
The request model for searches allows for combining any of the filters above. A search will only return context items that match all filters.
"filters": [
"live": false
"users": [
"conditions": [
"value": 12
5. Reactive Search endpoints
The Context API has two reactive endpoints:
a websocket using STOMP,
a minimal search streaming endpoint.
In contrast with the regular paged search API, items for which the user does not have the required permissions are not returned in the results
Both of these searches have some optional configuration:
| Parameter name | Default value | Description |
unlimited |
Maximum number of context items you want to receive. |
Maximum number of context items per message. Messages are pushed after 1 second in case the buffer is not full. |
Delay in milliseconds between two data pushes. |
5.1. Minimal Search
The minimal search endpoint returns only the context item’s identifier, the component it is linked to and its start and end date.
A request sent to the minimal search endpoint will return a stream.
5.2. Websocket
When the same level of detail in context items as in a regular HTTP search in required, the websocket approach can be used. The Context API’s websocket using the Simple Text Orientated Messaging Protocol, in short STOMP.
Using the websocket, it’s possible to setup a live search. Live searches will return context items in scope as soon as they are created, for as long as the websocket is open.
For more information on how to use the websocket using STOMP, please visit the STOMP specification.
5.2.1. Channels
The websocket provides three channels:
| Channel | Description |
Returns the context items. Messages contain lists of |
Returns errors in case any occur. |
Returns feedback if needed. Context will send a |
6. Loading a context view
A context item view consistent of a set of filters that are used to search context items, the type of the view and additional options depending on the view type. This section describes the steps to load the data produced by a context view using the API.
6.1. Getting the view
Context views are saved in the work-organiser. Use the work-organiser API to get the saved item, which will contain the identifier of the context view.
6.2. Enriching the view
The saved view in work-organiser still needs to be enriched with additional data before it is usable. An example of this is that only the identifier of a type in a type filter is saved, rather than the entire object including its name and description. The enrichment will also validate the filters, as certain objects could have been removed.
Tip
For more detailed information on the API, see Context View. |
6.2.1. Filter validation
When calling the enrich endpoint the views filters will be validated. Filters that are invallid will be marked with a flag "valid": false.
Prior to calling the search endpoint with the retrieved filter data, any filter issues should be resolved. Calling the search end point with invalid filters will result in a 400 Bad Request.
6.3. Performing the search
After enrichment and validation of the filter a search can be triggered to return the data for this view. This can be done in two ways:
using the paged API,
using a reactive streaming endpoint.
Tip
For more detailed information on the API, see Context Item. |
6.3.1. Paged search API
This end point performs a search with the provided filters and returns a list of results. These results can contain "redacted" results, meaning if there are context items for which the requester does not have the required permissions to view, they will not contain all the data. More information about searching can be found in the context item search section and in the context item section.
6.3.2. Reactive endpoints
See the section about reactive endpoints for more search options.
7. Context type access rules
Each context type has its own set of access rules, which determines what users can do with that context type. An access rules consist of
a list of permissions, which describes what can be done,
a subject, which defines who the access rule will apply to.
There are 3 different permissions:
user can read context items of this type |
user can create and modify context items of this type |
user can delete context items of this type |
For the sake of readability, going forward the prefix CONTEXT_TYPE_ will be omitted.
In the current release, the READ permission is not enforced, though it is highly recommended already giving users this permission when defining access rules with higher levels of control.
The above permissions can be granted to subjects, the subject types:
unauthenticated users |
all authenticated users |
all users in a given group |
a given user |
In the current release, the subject types GUEST and GROUP cannot be used yet.
When defining an access rule on a type, a combination of a subject and a set of permissions needs to be provided. When using the USER subject type, a user id also needs to be provided.
Tip
For more detailed information on the API, see Access Rules. |
7.1. Subject type priorities
Access rules are prioritized by subject type, meaning an access rule defined on USER has precedence over an access rule defined on EVERYONE (and so on when the other subject types will be implemented).
The following access rules exist:
permissions
READ,WRITEandDELETEon type ANOMALY for subject typeEVERYONE, -
permissions
READandWRITEon type ANOMALY for subject typeUSERfor user Bob.
This will result in Bob having the permissions READ and WRITE for that type, while other users also have
the DELETE permission.
When a new context type is created, a new access rule with subject type EVERYONE and permissions READ and WRITE is automatically created.
Users with administrator rights will always have all possible permissions available. |
8. Context item approvals
Approvals can be set on any context item for which approvals are enabled on its type.
A user can add an approval on a context item and delete said approval as often as needed, though only one approval per user per context item is possible at the same time. An approval will only be valid as long as certain properties of the context item do not change.
Changes (either using ContextHub or the API) that will remove all approvals from a context item include:
updating the description,
adding, updating or removing a keyword,
adding, updating or removing an event,
updating values for custom fields or other properties,
and adding or removing an attachment.
Comments do not affect approvals in any way.
Approvals can be enabled or disabled per context item type through ContextHub’s config pages or using the type API.
Tip
For more detailed information on the API, see Approvals. |
9. Context item attachments
To every context item for which the user has view and read permissions, attachments can be uploaded. For this, all mime-types and extensions are allowed. File size is limited to 20MB.
Updating the name, mine-type and extension after creation are only possible through the Context API.
The attachments on context items are exported when a backup is created. |
Tip
For more detailed information on the API, see Attachments. |
10. Context item comments
Anyone with the permissions to read a certain context item can read all existing comments and add comments.
Modifying or removing own comments is always possible, and will not have an influence on potentially present approvals. Users with admin privileges can remove or modify any comment.
Tip
For more detailed information on the API, see Comments. |
11. Context item history
A history of any changes made to tracked objects is kept on any context item for which history is enabled on its type.
Tracked objects on a context item are:
the context item itself, its components and its events,
attachments and comments,
and approvals.
Creating new, updating, or removing any of the above tracked objects on a history enabled context item will be tracked. This trail can be read by anyone with access to the context item and contains amongst the type of object also the user making the changes, the before and after values, and the date when the changes occurred.
Audit trail can be enabled or disabled per context item type through ContextHub’s config pages or using the type API.
Tip
For more detailed information on the API, see History. |
12. Resources
12.1. AccessRules
12.1.1. Create new
POST /type/{typeId}/accessrule
Parameters
Type |
Name |
Description |
Schema |
Path required |
typeId |
The identifier of the ContextItem type. |
String |
Body required |
TypeAccessRuleModel |
The access rule model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
AccessRule |
404 |
The resource was not found |
AccessRule |
201 |
Created |
AccessRule |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
application/hal+json
12.1.2. Delete specific
DELETE /type/{typeId}/accessrule/{accessRuleId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
typeId |
String |
Path required |
accessRuleId |
The identifier of the access rule. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
204 |
Deleted |
404 |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.1.3. Get specific
GET /type/{typeId}/accessrule/{accessRuleId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
typeId |
String |
Path required |
accessRuleId |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
AccessRule |
404 |
AccessRule |
200 |
OK |
AccessRule |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.1.4. Get all for type
Parameters
Type |
Name |
Description |
Schema |
Path required |
typeId |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
List[AccessRule] |
404 |
List[AccessRule] |
200 |
OK |
List[AccessRule] |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.1.5. Update specific
PUT /type/{typeId}/accessrule/{accessRuleId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
typeId |
String |
Path required |
accessRuleId |
String |
Body required |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
AccessRule |
404 |
AccessRule |
201 |
Created |
AccessRule |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.2. Analytics
12.2.1. Get all available aggregation operations
GET /analytics/aggregations/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
Identifier of the field or name of the property |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
CollectionModelAggregationOperationRepresentationModel |
404 |
No aggregations possible on this property or field |
ErrorMessage |
200 |
Ok |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.2.2. Calculate aggregations
POST /analytics/aggregations/{identifier}/aggregate
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Query required |
aggregation |
Name of the aggregation |
Body required |
SearchRequestModel |
Search request model |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
CollectionModelAggregationResultRepresentationModel |
404 |
One or more requested aggregations are not possible on this property or field |
ErrorMessage |
200 |
Ok |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.3. Approvals
12.3.1. Add approval
POST /data/{contextItemId}/approval
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextItemId |
The identifier of the ContextItem. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Approval |
403 |
No rights on this context item |
Approval |
400 |
Validation failed |
ErrorMessage |
201 |
Approved |
Approval |
404 |
EntityModel(s) not found! |
ErrorMessage |
Produces
application/json
12.3.2. Get all for item
GET /data/{contextItemId}/approval
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextItemId |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
List[Approval] |
404 |
EntityModel(s) not found |
ErrorMessage |
403 |
List[Approval] |
200 |
Ok |
List[Approval] |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.3.3. Revoke approval
DELETE /data/{contextItemId}/approval
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextItemId |
String |
Responses
HTTP Code |
Description |
Schema |
204 |
Revoked |
401 |
Unauthorized |
403 |
400 |
Validation failed |
ErrorMessage |
404 |
ErrorMessage |
Produces
application/json
12.4. AssetType
12.4.1. Add types to collection for assets
PATCH /asset-type
Parameters
Type |
Name |
Description |
Schema |
Body required |
AssetTypeModel |
The model containing the types to add to given assets. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
404 |
The resource was not found! |
ErrorMessage |
204 |
No Content |
String |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.4.2. Delete types from collection for assets
DELETE /asset-type
Parameters
Type |
Name |
Description |
Schema |
Body required |
AssetTypeModel |
The model containing the types to delete from given assets. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
404 |
ErrorMessage |
204 |
No Content |
String |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.4.3. Get types for assets
POST /asset-type
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Sorting criteria in the format: property(,asc |
Body required |
AssetModel |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
AssetType |
200 |
Ok |
AssetType |
Produces
application/json
12.4.4. Update entire collection of types for assets
PUT /asset-type
Parameters
Type |
Name |
Description |
Schema |
Body required |
AssetTypeModel |
The model containing the type collection to set for given assets. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
404 |
ErrorMessage |
204 |
No Content |
String |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.5. Attachments
12.5.1. Create new
POST /data/{contextDataId}/attachments
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data for which the attachment is created. |
String |
Query required |
name |
The name of the attachment. |
Query optional |
extension |
The extension of the attachment. |
Query optional |
type |
The mimeType of the attachment. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Attachment |
403 |
Forbidden! |
ErrorMessage |
201 |
Created |
Attachment |
400 |
Validation failed |
ErrorMessage |
404 |
ErrorMessage |
Produces
12.5.2. Delete specific
DELETE /data/{contextDataId}/attachments/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data the attachment belongs to |
String |
Path required |
identifier |
The identifier of the attachment to be deleted. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
403 |
Forbidden |
String |
200 |
Ok |
String |
404 |
ErrorMessage |
Produces
application/json
12.5.3. Download
GET /data/{contextDataId}/attachments/{identifier}/download
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
String |
Path required |
identifier |
The identifier of the attachment. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
403 |
Forbidden! |
ErrorMessage |
201 |
Created |
404 |
ErrorMessage |
Produces
12.5.4. Get all for item
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data to fetch all attachments from. |
String |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelAttachment |
403 |
Forbidden! |
ErrorMessage |
200 |
Ok |
404 |
ErrorMessage |
Produces
application/json
12.5.5. Get specific
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
String |
Path required |
identifier |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Attachment |
403 |
Forbidden! |
ErrorMessage |
201 |
Created |
Attachment |
404 |
ErrorMessage |
Produces
application/json
12.5.6. Update specific
PUT /data/{contextDataId}/attachments/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
String |
Path required |
identifier |
The identifier of the attachment to be updated. |
String |
Body required |
AttachmentModel |
The attachment model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Attachment |
403 |
Forbidden |
Attachment |
200 |
Ok |
Attachment |
404 |
ErrorMessage |
Produces
application/json
12.6. Comments
12.6.1. Create new coment on a context item
POST /data/{contextDataId}/comments
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data for which the comment is created. |
String |
Body required |
CommentModel |
The comment model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Comment |
201 |
Created |
Comment |
400 |
Validation failed |
ErrorMessage |
404 |
ErrorMessage |
Produces
application/json
12.6.2. Delete specific
DELETE /data/{contextDataId}/comments/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data the comment belongs to |
String |
Path required |
identifier |
The identifier of the comment to be deleted. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
403 |
Forbidden |
String |
200 |
Ok |
String |
404 |
ErrorMessage |
Produces
application/json
12.6.3. Get all comments for context item
GET /data/{contextDataId}/comments
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data to fetch all comments from. |
String |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelComment |
200 |
Ok |
PagedModelComment |
404 |
ErrorMessage |
Produces
application/json
12.6.4. Get all comments for context items in bulk
POST /data/comments
Parameters
Type |
Name |
Description |
Schema |
Body required |
IdListModel |
object containing a list of context item identifiers |
Produces
application/json
12.6.5. Get specific comment
GET /data/{contextDataId}/comments/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
String |
Path required |
identifier |
The identifier of the comment to be fetched. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Comment |
200 |
Ok |
Comment |
404 |
ErrorMessage |
Produces
application/json
12.6.6. Update specific
PUT /data/{contextDataId}/comments/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
String |
Path required |
identifier |
The identifier of the comment to be updated. |
String |
Body required |
CommentModel |
The updated comment model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Comment |
404 |
ErrorMessage |
403 |
Forbidden |
Comment |
200 |
Ok |
Comment |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.7. ContextData
12.7.1. Create new context data
POST /data
Parameters
Type |
Name |
Description |
Schema |
Body required |
ContextDataModel |
The context data model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextData |
404 |
ErrorMessage |
201 |
Created |
ContextData |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.7.2. Delete specific context data
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data to be deleted. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
200 |
Ok |
String |
404 |
ErrorMessage |
Produces
application/json
12.7.3. Get all context data
GET /data
Parameters
Type |
Name |
Description |
Schema |
Query optional |
useTimeSeriesIdentifier |
Indicates if time series identifier should be returned for tags references |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelContextData |
200 |
Ok |
Produces
application/json
12.7.4. Get a specific context data
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data to be fetched. |
String |
Query optional |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextData |
200 |
Ok |
ContextData |
404 |
ErrorMessage |
Produces
application/json
12.7.5. Search context data
GET /data/search
Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
The search query |
Query optional |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
400 |
Bad Request |
ErrorMessage |
200 |
Ok |
Produces
application/json
12.7.6. Update specific context data
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data to be updated. |
String |
Query optional |
Body required |
ContextDataModel |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextData |
404 |
ErrorMessage |
200 |
Ok |
ContextData |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.8. ContextDataEvent
12.8.1. Create new
POST /data/{contextDataId}/event
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data for which the event is created. |
String |
Body required |
ContextEventModel |
The event model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextEvent |
201 |
Created |
ContextEvent |
400 |
Validation failed |
ErrorMessage |
404 |
ErrorMessage |
Produces
application/json
12.8.2. Delete specific
DELETE /data/{contextDataId}/event/{eventId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data linked to the event to be deleted. |
String |
Path required |
eventId |
The identifier of the event to delete |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
200 |
Ok |
String |
404 |
ErrorMessage |
Produces
application/json
12.8.3. Get all for item
GET /data/{contextDataId}/event
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data to fetch all events from. |
String |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelContextEvent |
200 |
Ok |
404 |
ErrorMessage |
Produces
application/json
12.8.4. Get specific
GET /data/{contextDataId}/event/{eventId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data linked to the event to be fetched. |
String |
Path required |
eventId |
The identifier of the event to be fetched |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextEvent |
200 |
Ok |
ContextEvent |
404 |
ErrorMessage |
Produces
application/json
12.8.5. Update specific
PUT /data/{contextDataId}/event/{eventId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data linked to the event to be updated. |
String |
Path required |
eventId |
The identifier of the event that will be updated |
String |
Body required |
ContextEventModel |
The updated event model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextEvent |
404 |
ErrorMessage |
200 |
Ok |
ContextEvent |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.9. ContextDataReference
12.9.1. Add a new context data reference to a context data
POST /data/{contextDataId}/reference
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data for which the data reference is created. |
String |
Query optional |
Body required |
DataReferenceModel |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
DataReference |
201 |
Created |
DataReference |
400 |
Validation failed |
ErrorMessage |
404 |
ErrorMessage |
Produces
application/json
12.9.2. Delete specific
DELETE /data/{contextDataId}/reference/{referenceId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data linked to the reference to be deleted. |
String |
Path required |
referenceId |
The identifier of the data reference to be deleted. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
404 |
ErrorMessage |
204 |
Deleted |
String |
Produces
application/json
12.9.3. Get all for context data references for a specific context data
GET /data/{contextDataId}/reference
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data to fetch all the data references from. |
String |
Query optional |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelDataReference |
200 |
Ok |
404 |
ErrorMessage |
Produces
application/json
12.9.4. Get specific
GET /data/{contextDataId}/reference/{referenceId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data linked to the reference to be fetched. |
String |
Path required |
referenceId |
The identifier of the data reference to be fetched. |
String |
Query optional |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
DataReference |
200 |
Ok |
DataReference |
404 |
ErrorMessage |
Produces
application/json
12.9.5. Update specific
PUT /data/{contextDataId}/reference/{referenceId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context data linked to the reference to be updated. |
String |
Path required |
referenceId |
The identifier of the data reference that will be updated. |
String |
Query optional |
Body required |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
DataReference |
404 |
ErrorMessage |
200 |
Ok |
DataReference |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.10. ContextItem
12.10.1. Create new
POST /item
Parameters
Type |
Name |
Description |
Schema |
Query optional |
Body required |
ContextItemModel |
The context item model |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextItem |
404 |
ErrorMessage |
201 |
Created |
ContextItem |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.10.2. Create new in batch
POST /item/batch
Parameters
Type |
Name |
Description |
Schema |
Query optional |
async |
Indicates if the create in bulk should run async |
Body required |
ContextItemModel |
Array of context item models to create in batch. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
404 |
ErrorMessage |
201 |
Created |
String |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.10.3. Delete specific
DELETE /item/{contextDataId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context item to delete |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
200 |
Ok |
String |
404 |
ErrorMessage |
Produces
application/json
12.10.4. Delete bulk by definition
DELETE /item/batch/filters
Parameters
Type |
Name |
Description |
Schema |
Body required |
BulkDeleteByFiltersModel |
Model containing set of filters. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
202 |
Accepted: process is running in the background |
String |
403 |
Forbidden |
String |
404 |
ErrorMessage |
Produces
application/json
12.10.5. Delete bulk by identifiers
DELETE /item/batch
Parameters
Type |
Name |
Description |
Schema |
Body required |
BulkDeleteByIdentifiersModel |
Model containing list of identifiers. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
BulkDeleteResult |
403 |
Forbidden |
BulkDeleteResult |
200 |
Ok |
BulkDeleteResult |
404 |
ErrorMessage |
Produces
application/json
12.10.6. Get specific
GET /item/{contextDataId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context item to be fetched. |
String |
Query optional |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextItem |
200 |
Ok |
ContextItem |
404 |
ErrorMessage |
Produces
application/json
12.10.7. Search context items
POST /item/search
Parameters
Type |
Name |
Description |
Schema |
Query optional |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Body required |
Model containing the filter objects |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelContextItem |
400 |
Bad Request |
ErrorMessage |
200 |
Ok |
Produces
application/json
12.10.8. Minimal search (streaming)
POST /item/minimalSearch
Parameters
Type |
Name |
Description |
Schema |
Query optional |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Body required |
ReactiveSearchRequestModel |
Model containing the filter objects. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
200 |
OK |
List[MinimalContextItem] |
400 |
Bad Request |
ErrorMessage |
Produces
application/stream+json
application/json
12.10.9. Update specific
PUT /item/{contextDataId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
The identifier of the context item that will be updated |
String |
Query optional |
Body required |
ContextItemModel |
The updated context item model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextItem |
404 |
ErrorMessage |
200 |
Ok |
ContextItem |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.11. ContextItemV2
12.11.1. Returns the number of items matching the provided filters.
POST /v2/item/search/count
Parameters
Type |
Name |
Description |
Schema |
Body required |
Model containing the filters |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
CountRepresentationModel |
400 |
Bad Request |
ErrorMessage |
200 |
Ok |
Produces
application/json
12.11.2. Search context items V2
Parameters
Type |
Name |
Description |
Schema |
Body required |
CountIndependentSearchRequestModel |
Model containing the filter objects and paging information |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
TokenizedPageModelContextItem |
400 |
Bad Request |
ErrorMessage |
200 |
Ok |
Produces
application/json
12.12. ContextView
12.12.1. Enrich a saved context view
GET /view/{identifier}/enriched
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the context view to be fetched. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextView |
200 |
Ok |
ContextView |
404 |
ErrorMessage |
Produces
application/json
12.13. DataImportController
12.13.1. Delete a file.
DELETE /import/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The id of the file to delete. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
204 |
No content |
12.13.2. Download a file by id.
GET /import/{id}/download
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The id of the file to download. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
404 |
Resource(s) not found! |
200 |
Ok |
12.13.3. Download the generated error file for a specific file.
GET /import/{id}/errors
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The id of the file for which the error file should be retrieved. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
404 |
200 |
Ok |
12.13.4. List all imported files.
GET /import
Parameters
Type |
Name |
Description |
Schema |
Query required |
pageable |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PageDataImport |
200 |
Ok |
PageDataImport |
Produces
12.13.5. Get a file.
GET /import/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The id of the file to retrieve. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
DataImport |
404 |
DataImport |
200 |
Ok |
DataImport |
Produces
12.13.6. Upload a file.
POST /import
Parameters
Type |
Name |
Description |
Schema |
Path required |
name |
The name of the file. |
String |
Path required |
type |
The type of the file. |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
DataImport |
Produces
12.14. Export
12.14.1. Check existence
HEAD /export/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the export. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
204 |
No Content |
404 |
EntityModel not found |
410 |
Gone |
12.14.2. Remove all expired
DELETE /export/cleanup
Parameters
| Type | Name | Description | Schema |
Responses
HTTP Code |
Description |
Schema |
403 |
Forbidden |
204 |
Clean up is successful |
12.14.3. Create new
POST /export
Parameters
Type |
Name |
Description |
Schema |
Body required |
ExportModel |
The export creation model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
TaskSubmissionResult |
202 |
Accepted. |
404 |
View not found! |
ErrorMessage |
403 |
Forbidden! |
ErrorMessage |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.14.4. Get all
GET /export
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelExport |
200 |
Ok |
PagedModelExport |
Produces
application/json
12.14.5. Get export
GET /export/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
404 |
410 |
Gone |
200 |
Ok |
12.15. FailedEventFrameSynchronization
12.15.1. Re-sync one specific contextItem
POST /source/sync/failed/{failedItemId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
failedItemId |
The identifier of the context item to be re-synced |
UUID |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
200 |
ok |
400 |
Validation failed |
ErrorMessage |
Produces
12.15.2. Search
GET /source/sync/failed
Parameters
Type |
Name |
Description |
Schema |
Query optional |
query |
The search query |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelFailedEventFrameSynchronization |
400 |
Bad Request |
200 |
Ok |
Produces
12.16. Fields
12.16.1. Create new
POST /fields
Parameters
Type |
Name |
Description |
Schema |
Body required |
FieldModel |
The custom field model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Field |
201 |
Created |
Field |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.16.2. Delete specific
DELETE /fields/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the custom field to delete |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
200 |
Ok |
String |
404 |
ErrorMessage |
Produces
application/json
12.16.3. Get all
GET /fields
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelField |
200 |
Ok |
PagedModelField |
Produces
application/json
12.16.4. Get specific
GET /fields/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the custom field to be fetched. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Field |
200 |
Ok |
Field |
404 |
ErrorMessage |
Produces
application/json
12.16.5. Retrieve a list of fields linked to provided types.
POST /fields/linked
Parameters
Type |
Name |
Description |
Schema |
Query optional |
fieldTypes |
Allowed field types |
Body required |
string |
List of type identifiers. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
CollectionModelLinkedField |
400 |
Bad Request |
ErrorMessage |
200 |
Ok |
Produces
application/json
12.16.6. Search fields
GET /fields/search
Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
The search query |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelField |
400 |
Bad Request |
ErrorMessage |
200 |
Ok |
PagedModelField |
Produces
application/json
12.16.7. Update specific
PUT /fields/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the custom field that will be updated |
String |
Body required |
FieldModel |
The updated custom field model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Field |
404 |
ErrorMessage |
200 |
Ok |
Field |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.17. History
12.17.1. Get audit trail for item
GET /history/{contextDataId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextDataId |
String |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ErrorMessage |
403 |
Forbidden |
ErrorMessage |
200 |
Ok |
PagedModelAuditTrail |
400 |
Validation failed |
ErrorMessage |
404 |
ErrorMessage |
Produces
application/json
12.18. Keywords
12.18.1. Get all
GET /keywords
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelKeyword |
200 |
Ok |
PagedModelKeyword |
Produces
application/json
12.18.2. Search keywords
GET /keywords/search
Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
The search query |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelKeyword |
400 |
Bad Request |
ErrorMessage |
200 |
Ok |
PagedModelKeyword |
Produces
application/json
12.18.3. Validate a list of keywords
POST /keywords
Parameters
Type |
Name |
Description |
Schema |
Body required |
KeywordModel |
A collection of keyword models. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
List[Keyword] |
400 |
Validation failed |
ErrorMessage |
204 |
No content |
List[Keyword] |
Produces
application/json
12.19. PropertyKeyMigration
12.19.1. Download the Property key migration dry-run report
GET /migration/property-key/report
Parameters
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
404 |
Resource Not Found |
200 |
Ok |
12.19.2. Get field migrated keys uniqueness
GET /migration/property-key/field-uniqueness
Parameters
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
FieldUniquenessRepresentationModel |
200 |
Ok |
Produces
application/json
12.19.3. Get field dry-run results
GET /migration/property-key/fields
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelPropertyKeyMigrationFieldData |
200 |
Ok |
Produces
application/json
12.19.4. Get monitor dry-run results
GET /migration/property-key/monitors
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelPropertyKeyMigrationMonitorData |
200 |
Ok |
Produces
application/json
12.19.5. Get migration status
GET /migration/property-key/status
Parameters
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PropertyKeyMigrationStatusRepresentationModel |
200 |
Ok |
Produces
application/json
12.19.6. Get view dry-run results
GET /migration/property-key/views
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelPropertyKeyMigrationViewData |
200 |
Ok |
Produces
application/json
12.19.7. Update phase status
POST /migration/property-key/status
Parameters
Type |
Name |
Description |
Schema |
Body required |
PropertyKeyMigrationPhaseStatusModel |
Object holding the status for the waitingForApproval phase |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
204 |
No content |
String |
Produces
application/json
12.20. PublicDownloadGenerator
12.20.1. Generate
POST /download/generate
Parameters
Type |
Name |
Description |
Schema |
Body required |
LinkModel |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
DataModel |
Produces
application/json
12.21. Source
12.21.1. Get specific source
GET /source/{sourceIdentifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
sourceIdentifier |
The identifier of the source to be synced |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Source |
404 |
ErrorMessage |
200 |
Ok |
Source |
Produces
12.21.2. Search
GET /source/search
Parameters
Type |
Name |
Description |
Schema |
Query optional |
query |
The search query |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelSource |
400 |
Bad Request |
PagedModelSource |
200 |
Ok |
PagedModelSource |
Produces
12.21.3. Start historical sync
POST /source/{sourceIdentifier}/sync
Parameters
Type |
Name |
Description |
Schema |
Path required |
sourceIdentifier |
String |
Body required |
SourceSynchronizationIntervalModel |
Model containing the interval. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
202 |
Accepted |
400 |
Validation failed |
ErrorMessage |
Produces
12.21.4. Update specific source
PUT /source/{sourceIdentifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
sourceIdentifier |
The identifier of the source to be updated |
String |
Body required |
SourceModel |
Model containing the source. Only enabled flag can be changed. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Source |
404 |
Source |
200 |
Ok |
Source |
400 |
Validation failed |
ErrorMessage |
Produces
12.22. SourceSynchronization
12.22.1. Do a manual cleanup of one datasource
POST /source/sync/cleanup
Parameters
Type |
Name |
Description |
Schema |
Query required |
datasourceId |
The identifier of the datasource |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
202 |
Accepted |
400 |
Validation failed |
ErrorMessage |
Produces
12.22.2. Re-sync specific context item
POST /source/sync/{contextItemIdentifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
contextItemIdentifier |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextItem |
204 |
No Content |
ContextItem |
200 |
Ok |
ContextItem |
400 |
Validation failed |
ErrorMessage |
Produces
12.22.3. Re-sync list of context items
POST /source/sync/filters
Parameters
Type |
Name |
Description |
Schema |
Body required |
BulkResyncByFiltersModel |
Model containing the list of filters. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
202 |
Accepted |
400 |
Validation failed |
ErrorMessage |
Produces
12.22.4. Re-sync list of context items
POST /source/sync
Parameters
Type |
Name |
Description |
Schema |
Body required |
BulkResyncByIdentifiersModel |
Model containing the list of context item identifiers. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
202 |
Accepted |
400 |
Validation failed |
ErrorMessage |
Produces
12.23. SourceSynchronizationInBackground
12.23.1. Cancel historical background sync job
DELETE /source/sync/background/{syncJobIdentifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
syncJobIdentifier |
The identifier of the sync job |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
BackgroundSyncJobRepresentationModel |
400 |
Bad Request |
404 |
ErrorMessage |
200 |
Ok |
Produces
12.23.2. Get background sync job
GET /source/sync/background/{syncJobIdentifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
syncJobIdentifier |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
404 |
ErrorMessage |
200 |
Ok |
Produces
12.23.3. Search background sync jobs
Parameters
Type |
Name |
Description |
Schema |
Query optional |
query |
The search query |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelBackgroundSyncJobRepresentationModel |
200 |
Ok |
Produces
12.23.4. Update background sync job status
PUT /source/sync/background/{syncJobIdentifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
syncJobIdentifier |
String |
Body required |
BackgroundSyncJobStatusModel |
Model containing the new status. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
404 |
ErrorMessage |
200 |
Ok |
Produces
12.24. Triggers
12.24.1. Create new
POST /type/{typeId}/triggers
Parameters
Type |
Name |
Description |
Schema |
Path required |
typeId |
The identifier of the context data type for which the trigger is created. |
String |
Body required |
TriggerDefinitionModel |
The trigger model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
TriggerDefinition |
403 |
Forbidden! |
ErrorMessage |
201 |
Created |
TriggerDefinition |
400 |
Validation failed |
ErrorMessage |
404 |
ErrorMessage |
Produces
application/json
12.24.2. Delete specific
DELETE /type/{typeId}/triggers/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
typeId |
The identifier of the context data type the trigger is attached to. |
String |
Path required |
identifier |
The identifier of the trigger to delete |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
403 |
Forbidden! |
ErrorMessage |
200 |
Ok |
String |
404 |
ErrorMessage |
Produces
application/json
12.24.3. Get all for type
GET /type/{typeId}/triggers
Parameters
Type |
Name |
Description |
Schema |
Path required |
typeId |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelTriggerDefinition |
403 |
Forbidden! |
ErrorMessage |
200 |
Ok |
404 |
ErrorMessage |
Produces
application/json
12.24.4. Get specific
GET /type/{typeId}/triggers/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
typeId |
String |
Path required |
identifier |
The identifier of the trigger to be fetched. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
TriggerDefinition |
403 |
Forbidden! |
ErrorMessage |
200 |
Ok |
TriggerDefinition |
404 |
ErrorMessage |
Produces
application/json
12.24.5. Update specific
PUT /type/{typeId}/triggers/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
typeId |
String |
Path required |
identifier |
The identifier of the trigger to update |
String |
Body required |
The updated trigger model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
TriggerDefinition |
403 |
Forbidden! |
ErrorMessage |
400 |
Validation failed |
ErrorMessage |
204 |
No content |
TriggerDefinition |
404 |
ErrorMessage |
Produces
application/json
12.25. Type
12.25.1. Create new
POST /type
Parameters
Type |
Name |
Description |
Schema |
Body required |
ContextDataTypeModel |
The context date type model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextDataType |
201 |
Created |
ContextDataType |
400 |
Validation failed |
ErrorMessage |
404 |
ErrorMessage |
Produces
application/json
12.25.2. Delete specific context data type.
DELETE /type/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the type to delete |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
200 |
Ok |
String |
404 |
ErrorMessage |
Produces
application/json
12.25.3. Get all context data types
GET /type
Parameters
Type |
Name |
Description |
Schema |
Query optional |
assetId |
When provided, only types allowed for this asset are returned. |
Query optional |
hasPermission |
Type permissions the user needs to have. Possible values: CONTEXT_TYPE_WRITE or CONTEXT_TYPE_DELETE. When CONTEXT_TYPE_DELETE is provided, CONTEXT_TYPE_WRITE is automatically assumed. |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelContextDataType |
200 |
Ok |
Produces
application/json
12.25.4. Get specific
GET /type/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the type to be fetched |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextDataType |
200 |
Ok |
ContextDataType |
404 |
ErrorMessage |
Produces
application/json
12.25.5. Search context data types.
GET /type/search
Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
The search query |
Query optional |
hasPermission |
Query optional |
includeDeleted |
Whether to include deleted types or not. |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
400 |
Bad Request |
ErrorMessage |
200 |
Ok |
Produces
application/json
12.25.6. Search context data types using a POST request.
POST /type/search
Parameters
Type |
Name |
Description |
Schema |
Body required |
SearchParametersModel |
Search request model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
400 |
Bad Request |
ErrorMessage |
200 |
Ok |
Produces
application/json
12.25.7. Update specific
PUT /type/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the type that will be updated |
String |
Body required |
The updated context date type model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
ContextDataType |
404 |
ErrorMessage |
200 |
Ok |
ContextDataType |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.26. Workflow
12.26.1. Create new
POST /workflow
Parameters
Type |
Name |
Description |
Schema |
Body required |
WorkflowModel |
The workflow model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Workflow |
201 |
Created |
Workflow |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.26.2. Delete specific workflow.
DELETE /workflow/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the work flow to delete. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
String |
204 |
No content |
String |
404 |
ErrorMessage |
Produces
application/json
12.26.3. Get all workflows
GET /workflow
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelWorkflow |
200 |
Ok |
Produces
application/json
12.26.4. Gets specific
GET /workflow/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the workflow to be fetched. |
String |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Workflow |
200 |
Ok |
Workflow |
404 |
ErrorMessage |
Produces
application/json
12.26.5. Search for workflows
GET /workflow/search
Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
The search query |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
400 |
Bad Request |
ErrorMessage |
200 |
Ok |
Produces
application/json
12.26.6. Search for workflow states
GET /workflow/states/search
Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
The search query |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
PagedModelString |
400 |
Bad Request |
ErrorMessage |
200 |
Ok |
PagedModelString |
Produces
application/json
12.26.7. Update workflow
PUT /workflow/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the workflow that will be updated. |
String |
Body required |
WorkflowModel |
The updated workflow model. <br/>Can only add new intermediate states to the workflow model and update the name. <br/>Deletion of states is not allowed. Start- and end-states can not be updated. <br/>Identifier can not be updated |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
Workflow |
404 |
ErrorMessage |
200 |
Ok |
Workflow |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
12.26.8. Update workflow states
PUT /workflow/{identifier}/states
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Body required |
WorkflowStatesModel |
The updated workflow states model. |
Responses
HTTP Code |
Description |
Schema |
401 |
Unauthorized |
WorkflowStates |
404 |
ErrorMessage |
200 |
Ok |
WorkflowStates |
400 |
Validation failed |
ErrorMessage |
Produces
application/json
13. Models
13.1. AccessRule
Represents an access rule definition
| Field Name | Required | Type | Description | Format |
identifier |
String |
objectId |
X |
String |
The identifier of the object. |
paths |
X |
List of [string] |
An array of paths towards the object. |
subjectId |
X |
String |
The identifier of the subject. |
subjectType |
X |
String |
The type of the subject: USER, GROUP, EVERYBODY, GUEST. |
Enum: GUEST, EVERYONE, GROUP, USER, |
permissions |
X |
Set of [string] |
A set of permissions the subject has on the specified object. Can be an empty set. |
Enum: |
userDetailsResource |
PermissionUserDetails |
links |
List of Link |
13.2. AggregationDefinition
The aggregations that are defined on this field
name |
String |
13.3. AggregationOperationRepresentationModel
name |
String |
queryType |
String |
Enum: MEDIAN, MOST_COMMON, LEAST_COMMON, REGULAR, |
returnType |
String |
Enum: NUMERIC, STRING, DURATION, |
links |
List of Link |
13.4. AggregationResultRepresentationModel
operation |
value |
Object |
links |
List of Link |
13.5. Approval
identifier |
String |
The identifier of the approval. |
createdDate |
Date |
The date when the approval was given. |
date-time |
createdBy |
String |
The approver's user id. |
userDetails |
UserDetails |
links |
List of Link |
13.6. ApprovalFilter
Represents an Approval filter definition
type |
String |
Enum: INTERVAL_FILTER, LIVE_INTERVAL_FILTER, PERIOD_FILTER, COMPONENT_FILTER, TYPE_FILTER, KEYWORD_FILTER, STRING_FIELD_FILTER, ENUMERATION_FIELD_FILTER, NUMERIC_FIELD_FILTER, PROPERTY_FIELD_FILTER, CREATED_BY_FILTER, DESCRIPTION_FILTER, DURATION_FILTER, APPROVAL_FILTER, CURRENT_STATE_FILTER, CREATED_DATE_FILTER, EXTERNAL_FILTER, |
valid |
Boolean |
validationResultMessages |
List of ValidationResultMessage |
order |
Integer |
int32 |
withApprovals |
Boolean |
Filter context items with or with an approvals |
13.7. ApprovalFilterAllOf
withApprovals |
Boolean |
13.8. Asset
Represents an asset
identifier |
UUID |
The asset's identifier. |
uuid |
paths |
List of [string] |
The paths towards this asset starting from the root. |
longPaths |
List of [string] |
The old longer paths towards this asset starting from the root. |
parentNames |
List of [string] |
The names of the parents, in the same order as the paths. |
name |
String |
The asset's name. |
description |
String |
The asset's description. |
type |
String |
The asset's type. |
dataType |
String |
The asset's data type, if the Asset is an ATTRIBUTE. |
data |
String |
The asset's data, if the Asset is an ATTRIBUTE. (tagName or UUID) |
timeSeriesDefinition |
TimeSeriesDefinitionRepresentation |
deleted |
Boolean |
Indication whether this asset is deleted or not. |
externalId |
String |
The asset's identifier in the external system. |
template |
String |
The asset's template. |
templateId |
String |
The asset's template identifier. |
source |
Source |
permissions |
List of [string] |
The asset's permissions. |
Enum: |
links |
List of Link |
13.9. AssetModel
Collection of assets
assets |
Set of [UUID] |
Set of asset identifiers |
uuid |
13.10. AssetType
Represents a mapping between types and their allowed assets
types |
inheritance |
String |
Inheritance type of the rule. |
Enum: ALL, SELF, INHERITED, |
inherited |
List of Asset |
Assets of which the rules were inherited |
links |
List of Link |
13.11. AssetTypeModel
Collections of assets and types
assets |
Set of [UUID] |
uuid |
types |
Set of [string] |
Set of type identifiers |
13.12. Attachment
Represents a attachment definition
identifier |
String |
The identifier of the attachment |
name |
X |
String |
The name of the attachment |
type |
String |
The mine type of the attachment |
extension |
String |
The extension of the attachment |
createdDate |
Date |
The date when the attachment was created |
date-time |
lastModifiedDate |
Date |
The date of the last modification of the attachment |
date-time |
createdBy |
String |
The user who created the attachment |
lastModifiedBy |
String |
The user who made the latest update to the attachment |
links |
List of Link |
13.13. AttachmentModel
Represents an attachment definition
name |
X |
String |
extension |
String |
type |
String |
The type of the attachment |
13.14. AuditTrail
Represents an audit trail definition
identifier |
String |
The identifier of the audit trail |
contextDataIdentifier |
String |
The identifier of the context item |
changedItemIdentifier |
String |
The identifier of the changed entity |
changedItemType |
String |
The type of the changed entity |
changedDate |
Date |
The date at which the changes occurred |
date-time |
changedBy |
String |
The identifier of the user who made the changes |
action |
String |
The action performed |
changes |
List of [map] |
The changes |
userDetails |
UserDetails |
links |
List of Link |
13.15. BackgroundSyncJobRepresentationModel
Represents an interval to synchronize in the background
identifier |
UUID |
The identifier of this sync job |
uuid |
source |
Source |
type |
String |
Type of background sync |
Enum: EXCESSIVE, HISTORICAL, CLEANUP_NIGHTLY, CLEANUP_MANUAL, CLEANUP_AFTER_AF, |
status |
String |
Status of this background sync. |
Enum: WAITING_FOR_SCHEDULING, SCHEDULED, WAITING, RUNNING, DONE, CANCELLED, FAILED, |
intervalStart |
Date |
Lower end of the interval to be synced |
date-time |
intervalEnd |
Date |
Upper end of the interval to be synced |
date-time |
intervalCount |
Integer |
Number of items in the interval to be synced |
int32 |
intervalPage |
Integer |
Current page of the interval being synced |
int32 |
submitDate |
Date |
Date this background interval was submitted to the queue |
date-time |
startDate |
Date |
Date the synchronization process started |
date-time |
endDate |
Date |
Date the synchronization process ended |
date-time |
holdDate |
Date |
Date the synchronization process was put on hold |
date-time |
resumeDate |
Date |
Date the synchronization process resumed |
date-time |
holdCount |
Integer |
Number of times the synchronization process was put on hold |
int32 |
lastSyncedItemDate |
Date |
Last modified date of the last synced item |
date-time |
exceptionMessage |
String |
Exception message, should one have occurred in the current interval |
data |
Map of [object] |
Additional data related to the job |
cancelable |
Boolean |
links |
List of Link |
13.16. BackgroundSyncJobStatusModel
Represents a status for a background sync interval.
status |
String |
13.17. BulkDeleteByFiltersModel
Represents the definition for a context item bulk delete by filters action
filters |
X |
List of filters to which context items have to match to be deleted. Mutually exclusive with identifiers field. |
createdBefore |
X |
Date |
Date before which context items need to be created to be deleted when using the filters. Mutually exclusive with identifiers field. Will default to request date. |
date-time |
13.18. BulkDeleteByIdentifiersModel
Represents the definition for a context item bulk delete by identifiers action
identifiers |
X |
List of [UUID] |
List of context item identifiers to be deleted. Mutually exclusive with the other fields. |
uuid |
13.19. BulkDeleteResult
Represents the result of a bulk delete action.
deleted |
Integer |
The number of deleted context items. |
int32 |
remaining |
Integer |
The number of remaining context item created before the provided date. |
int32 |
13.20. BulkResyncByFiltersModel
Represents the definition for a context item resync by filters action
filters |
X |
List of filters to which context items have to match to be resynced. |
createdBefore |
X |
Date |
Date before which context items need to be created to be resync when using the filters. Will default to request date. |
date-time |
13.21. BulkResyncByIdentifiersModel
Represents the definition for a context item resync by identifiers action
identifiers |
X |
List of [UUID] |
List of context item identifiers to be resynced. |
uuid |
13.22. CollectionModelAggregationOperationRepresentationModel
links |
List of Link |
content |
13.23. CollectionModelAggregationResultRepresentationModel
links |
List of Link |
content |
13.24. CollectionModelLinkedField
links |
List of Link |
content |
List of LinkedField |
13.25. ColumnSettingsView
Settings for the table view (frontend related)
general |
List of GeneralColumn |
fields |
List of FieldModelColumn |
13.26. Comment
Represents a comment definition
identifier |
String |
The identifier of the comment |
content |
X |
String |
The content of the comment |
createdDate |
Date |
The date when the comment was created |
date-time |
lastModifiedDate |
Date |
The date of the last modification of the comment |
date-time |
createdBy |
String |
lastModifiedBy |
String |
userDetails |
UserDetails |
links |
List of Link |
13.27. CommentModel
content |
X |
String |
The comment content |
13.28. ComponentFilter
Represents a Component filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
mode |
String |
components |
List of ComponentValue |
includeAncestors |
Boolean |
componentResources |
List of ContextItemComponent |
numComponents |
Integer |
int32 |
resolvedComponents |
Set of [string] |
13.29. ComponentFilterAllOf
mode |
String |
components |
includeAncestors |
Boolean |
numComponents |
Integer |
int32 |
Set of [string] |
13.30. ComponentValue
identifier |
String |
path |
String |
type |
X |
String |
include |
String |
Enum: SELF, ANCESTORS, DESCENDANTS, |
13.31. ContextData
Represents a context data definition
identifier |
String |
The identifier of the context data |
shortKey |
String |
The short key of the context event |
description |
String |
The description of the context data |
externalId |
String |
The external identifier of the context data |
type |
ContextDataType |
keywords |
Set of [string] |
The keywords for this context data |
fields |
Map of [object] |
The optional fields as their key and values |
permissions |
Set of [string] |
Permissions on the context data |
links |
List of Link |
13.32. ContextDataModel
type |
X |
description |
String |
externalId |
String |
The external id of the context data |
keywords |
X |
Set of [string] |
The keywords the context data is tagged with |
fields |
Map of [object] |
13.33. ContextDataType
Represents a context data type definition
identifier |
String |
The identifier of the context data type |
name |
String |
The name of the context data type |
workflow |
Workflow |
color |
String |
The color of the context data type in hex value |
icon |
String |
The icon name of the context data type |
externalId |
String |
The external id of the context data type |
deleted |
Boolean |
Boolean that indicates if the context data type is deleted |
deletable |
Boolean |
Boolean that indicates if the context data type is deletable |
approvalsEnabled |
Boolean |
Boolean that indicates whether approvals are enabled or not |
auditTrailEnabled |
Boolean |
Boolean that indicates whether audit trail is enabled or not |
fields |
List of Field |
permissions |
Set of [string] |
Set of permissions the current user has on this type |
fieldLabelIdentifier |
String |
The id of the custom field that will be used as a label on gantt view |
source |
Source |
links |
List of Link |
13.34. ContextDataTypeModel
identifier |
String |
The identifier of the context data type. If empty, one will be generated |
source |
SourceModel |
externalId |
String |
The identifier of the type in the external source system |
name |
X |
String |
workflow |
WorkflowModel |
color |
String |
icon |
X |
String |
fields |
List of FieldModel |
The custom fields linked to this context data type |
deletable |
Boolean |
If the ContextDataType is deletable or not |
approvalsEnabled |
Boolean |
Whether the ContextDataType has approvals enabled or not |
auditTrailEnabled |
Boolean |
Whether the ContextDataType has audit trail enabled or not |
UUID |
uuid |
13.35. ContextEvent
Represents a context event definition
identifier |
String |
The identifier of the context event |
occurred |
Date |
The timestamp when this event took place |
date-time |
state |
String |
The state of this event |
links |
List of Link |
13.36. ContextEventModel
state |
String |
The state of the event, can be stateless if the context item does not describe a workflow |
occurred |
X |
Date |
The date on which the event occurred |
date-time |
13.37. ContextItem
permissions |
Set of [string] |
identifier |
String |
shortKey |
String |
The short key of the context item |
externalId |
String |
The external system's original id |
description |
String |
The description of the context item |
events |
List of ContextEvent |
The events of the context item |
lastModifiedDate |
Date |
The date of the most recent event of the context item |
date-time |
createdBy |
String |
The uuid of the user who created the context item |
createdDate |
Date |
The date this context item was created |
date-time |
userDetails |
UserDetails |
components |
The components for which the context item is registered |
type |
ContextDataType |
workFlowDescribed |
Boolean |
True if the context item type has a workflow |
fields |
Map of [object] |
Contains the optional fields as their key and values |
keywords |
Set of [string] |
startEventDate |
Date |
The date of the start event of the context item |
date-time |
endEventDate |
Date |
The date of the end event |
date-time |
lastEventState |
String |
The state of the most recent event of the context item |
totalDuration |
String |
The total duration of the context item |
links |
List of Link |
13.38. ContextItemComponent
The component for which the context item is registered
identifier |
String |
name |
String |
description |
String |
type |
String |
reference |
String |
parentName |
String |
path |
String |
permissions |
Set of [string] |
deleted |
Boolean |
include |
String |
13.39. ContextItemComponentModel
Represents a data reference definition
type |
X |
String |
The data reference type |
reference |
X |
String |
The id of the referenced data |
identifier |
String |
The identifier of the data reference |
13.40. ContextItemEventModel
state |
String |
occurred |
X |
Date |
date-time |
identifier |
String |
13.41. ContextItemModel
Represents a context item definition
description |
String |
externalId |
String |
events |
X |
List of ContextItemEventModel |
components |
List of ContextItemComponentModel |
The components of the context item |
type |
X |
keywords |
Set of [string] |
fields |
Map of [object] |
13.42. ContextView
Represents a context view definition
description |
String |
folder |
Boolean |
identifier |
String |
lastModifiedDate |
Date |
date-time |
name |
String |
owner |
String |
ownerUuid |
String |
shared |
Boolean |
data |
ContextViewData |
permissions |
List of [string] |
parentId |
String |
links |
List of Link |
13.43. ContextViewData
filters |
List of filters |
viewType |
String |
Type of the view (frontend related |
columnSettings |
ColumnSettingsView |
ganttSettings |
Object |
Settings for the gantt view (frontend related) |
sortSettings |
Object |
Sort settings |
scatterSettings |
Object |
Scatter settings |
gridSettings |
Object |
Grid settings |
13.44. CountIndependentSearchRequestModel
Represents a search request definition used in the count independent search.
filters |
sortDirection |
String |
The sorting direction. |
sortProperties |
List of [string] |
List of properties to sort on. The order of the list is the sorting order. First sort on Index 0 then on 1 to n-1. |
fetchSize |
Integer |
Number of items to fetch. |
int32 |
continuationToken |
String |
Token generated by the service that represent a marker for where the previous page ended. |
13.45. CountRepresentationModel
totalCount |
Long |
int64 |
13.46. CreatedByFilter
Represents a CreatedBy filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
users |
X |
List of [string] |
userDetails |
List of UserDetails |
13.47. CreatedByFilterAllOf
users |
List of [string] |
userDetails |
13.48. CreatedDateFilter
Represents a created date filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
createdDate |
X |
Date |
date-time |
operator |
X |
String |
Enum: EQUAL, NOT_EQUAL, LESS_THAN, LESS_THAN_OR_EQUAL, GREATER_THAN, GREATER_THAN_OR_EQUAL, |
13.49. CreatedDateFilterAllOf
createdDate |
Date |
date-time |
operator |
String |
13.50. CurrentStateFilter
Represents a Current state filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
states |
List of [string] |
mode |
String |
13.51. CurrentStateFilterAllOf
states |
List of [string] |
mode |
String |
13.52. DataImport
id |
String |
name |
String |
type |
String |
created |
Date |
date-time |
createdBy |
String |
modified |
Date |
date-time |
status |
String |
Enum: UPLOADED, COMPLETED, COMPLETED_WITH_ERRORS, FAILED, |
errors |
Long |
int64 |
errorMessage |
String |
parameters |
List of Parameter |
errorsFileName |
String |
fileName |
String |
13.53. DataModel
data |
String |
the signed link data |
13.54. DataReference
identifier |
String |
type |
X |
String |
reference |
X |
String |
links |
List of Link |
13.55. DataReferenceModel
type |
X |
String |
reference |
X |
String |
13.56. DescriptionFilter
Represents a Description filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
values |
List of [string] |
mode |
String |
13.57. DescriptionFilterAllOf
values |
List of [string] |
mode |
String |
13.58. DurationCondition
Represents a duration condition definition
value |
String |
operator |
X |
String |
13.59. DurationFilter
Represents a value filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
conditions |
X |
List of DurationCondition |
13.60. DurationFilterAllOf
conditions |
13.61. EnumerationFieldFilter
Represents an Enumeration Field filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
fieldIdentifier |
UUID |
uuid |
field |
String |
values |
List of [string] |
customField |
Field |
mode |
String |
13.62. EnumerationFieldFilterAllOf
fieldIdentifier |
UUID |
uuid |
field |
String |
values |
List of [string] |
customField |
Field |
mode |
String |
13.63. ErrorDetail
defaultMessage |
String |
13.64. ErrorMessage
Represents a tm-context exception
statusCode |
String |
The httpStatus code of the exception |
Enum: 100 CONTINUE, 101 SWITCHING_PROTOCOLS, 102 PROCESSING, 103 CHECKPOINT, 200 OK, 201 CREATED, 202 ACCEPTED, 203 NON_AUTHORITATIVE_INFORMATION, 204 NO_CONTENT, 205 RESET_CONTENT, 206 PARTIAL_CONTENT, 207 MULTI_STATUS, 208 ALREADY_REPORTED, 226 IM_USED, 300 MULTIPLE_CHOICES, 301 MOVED_PERMANENTLY, 302 FOUND, 302 MOVED_TEMPORARILY, 303 SEE_OTHER, 304 NOT_MODIFIED, 305 USE_PROXY, 307 TEMPORARY_REDIRECT, 308 PERMANENT_REDIRECT, 400 BAD_REQUEST, 401 UNAUTHORIZED, 402 PAYMENT_REQUIRED, 403 FORBIDDEN, 404 NOT_FOUND, 405 METHOD_NOT_ALLOWED, 406 NOT_ACCEPTABLE, 407 PROXY_AUTHENTICATION_REQUIRED, 408 REQUEST_TIMEOUT, 409 CONFLICT, 410 GONE, 411 LENGTH_REQUIRED, 412 PRECONDITION_FAILED, 413 PAYLOAD_TOO_LARGE, 413 REQUEST_ENTITY_TOO_LARGE, 414 URI_TOO_LONG, 414 REQUEST_URI_TOO_LONG, 415 UNSUPPORTED_MEDIA_TYPE, 416 REQUESTED_RANGE_NOT_SATISFIABLE, 417 EXPECTATION_FAILED, 418 I_AM_A_TEAPOT, 419 INSUFFICIENT_SPACE_ON_RESOURCE, 420 METHOD_FAILURE, 421 DESTINATION_LOCKED, 422 UNPROCESSABLE_ENTITY, 423 LOCKED, 424 FAILED_DEPENDENCY, 425 TOO_EARLY, 426 UPGRADE_REQUIRED, 428 PRECONDITION_REQUIRED, 429 TOO_MANY_REQUESTS, 431 REQUEST_HEADER_FIELDS_TOO_LARGE, 451 UNAVAILABLE_FOR_LEGAL_REASONS, 500 INTERNAL_SERVER_ERROR, 501 NOT_IMPLEMENTED, 502 BAD_GATEWAY, 503 SERVICE_UNAVAILABLE, 504 GATEWAY_TIMEOUT, 505 HTTP_VERSION_NOT_SUPPORTED, 506 VARIANT_ALSO_NEGOTIATES, 507 INSUFFICIENT_STORAGE, 508 LOOP_DETECTED, 509 BANDWIDTH_LIMIT_EXCEEDED, 510 NOT_EXTENDED, 511 NETWORK_AUTHENTICATION_REQUIRED, |
errorCode |
String |
The specific error code of the exception |
message |
String |
The exception message |
details |
Object |
The details of the exception |
13.65. Export
Represents an export
identifier |
UUID |
uuid |
type |
String |
Enum: CSV_COMMA_SEPARATED, CSV_SEMICOLON_SEPARATED, XLSX, ZIP, |
downloadName |
String |
createdBy |
String |
createdDate |
Date |
date-time |
lastDownloadDate |
Date |
date-time |
links |
List of Link |
13.66. ExportModel
Represents an export creation definition
viewIdentifier |
X |
String |
The identifier of the view to be exported |
type |
X |
String |
The type of the export |
Enum: CSV_COMMA_SEPARATED, CSV_SEMICOLON_SEPARATED, XLSX, ZIP, CSV_COMMA_SEPARATED,CSV_SEMICOLON_SEPARATED,XLSX, |
timezone |
String |
The timezone in which to display all times |
hostname |
String |
The TrendMiner hostname |
13.67. FailedEventFrameSynchronization
Represents a source and its synchronization status
identifier |
UUID |
The identifier of the failed event frame synchronization |
uuid |
source |
Source |
externalId |
String |
The identifier of the event frame in the source system |
failureDate |
Date |
The date when the failure of syncing occurred |
date-time |
exceptionMessage |
String |
The failure's exception message |
links |
List of Link |
13.68. Field
Represents a custom field definition
identifier |
String |
The identifier of the field |
propertyKey |
String |
The technical identifier of the field |
name |
X |
String |
The name of the field |
type |
X |
String |
The field type, must be one of these values: STRING, NUMERIC, ENUMERATION |
placeholder |
String |
The placeholder of the field, an example value for what this field's value might look like |
options |
List of [string] |
The possible options of the field, only applicable when type Enumeration is chosen |
aggregations |
List of AggregationDefinition |
The aggregations that are defined on this field |
links |
List of Link |
13.69. FieldFilter
type |
String |
valid |
Boolean |
fieldIdentifier |
UUID |
uuid |
field |
String |
order |
Integer |
int32 |
13.70. FieldModel
identifier |
UUID |
uuid |
propertyKey |
X |
String |
The property key of the field |
name |
X |
String |
type |
X |
String |
placeholder |
String |
options |
List of [string] |
13.71. FieldModelColumn
identifier |
String |
propertyKey |
String |
name |
X |
String |
type |
X |
String |
placeholder |
String |
options |
List of [string] |
aggregations |
order |
Integer |
int32 |
width |
Integer |
int32 |
links |
List of Link |
13.72. FieldUniquenessRepresentationModel
unique |
Boolean |
13.73. Filter
Represents the base Filter
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
13.74. GeneralColumn
name |
String |
order |
Integer |
int32 |
width |
Integer |
int32 |
aggregations |
The aggregations that are defined on this column |
13.75. I18nMessage
code |
ErrorDetail |
message |
String |
parameters |
Map of [object] |
13.76. IdListModel
Model for a List containing UUID
uuidList |
List of [UUID] |
uuid |
13.77. IntervalFilter
Represents a Interval filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
startDate |
X |
Date |
The start of the filter segment |
date-time |
endDate |
X |
Date |
The end of the filter segment |
date-time |
intervalType |
X |
String |
The intervalType: EVENT(default) or CREATED_DATE |
13.78. IntervalFilterAllOf
startDate |
Date |
date-time |
endDate |
Date |
date-time |
intervalType |
String |
13.79. Keyword
Represents a keyword definition
keyword |
String |
The keyword |
links |
List of Link |
13.80. KeywordFilter
Represents a Keyword filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
keywords |
List of [string] |
mode |
String |
13.81. KeywordFilterAllOf
keywords |
List of [string] |
mode |
String |
13.82. KeywordModel
keyword |
X |
String |
The string value representing a keyword |
13.83. Link
rel |
String |
href |
String |
hreflang |
String |
media |
String |
title |
String |
type |
String |
deprecation |
String |
profile |
String |
name |
String |
13.84. LinkModel
link |
X |
String |
The requested link. |
validity |
Long |
int64 |
13.85. LinkedField
Represents a custom field definition with an indication of usage over provided types
identifier |
String |
propertyKey |
String |
name |
X |
String |
type |
X |
String |
placeholder |
String |
options |
List of [string] |
aggregations |
all |
Boolean |
Indicates whether the field is present on all or just some provided types. |
links |
List of Link |
13.86. LiveIntervalFilter
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
13.87. MinimalContextItem
permissions |
Set of [string] |
identifier |
String |
components |
The component for which the context item is registered |
startEventDate |
Date |
date-time |
endEventDate |
Date |
date-time |
links |
List of Link |
13.88. NumericCondition
Represents a numeric condition definition
value |
X |
Double |
double |
operator |
X |
String |
13.89. NumericFieldFilter
Represents a Numeric Field filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
fieldIdentifier |
UUID |
uuid |
field |
String |
conditions |
List of NumericCondition |
customField |
Field |
mode |
String |
13.90. NumericFieldFilterAllOf
fieldIdentifier |
UUID |
uuid |
field |
String |
conditions |
customField |
Field |
mode |
String |
13.91. PageDataImport
totalPages |
Integer |
int32 |
totalElements |
Long |
int64 |
first |
Boolean |
last |
Boolean |
numberOfElements |
Integer |
int32 |
pageable |
Pageable |
sort |
Sort |
size |
Integer |
int32 |
content |
List of DataImport |
number |
Integer |
int32 |
empty |
Boolean |
13.92. PageMetadata
size |
Long |
int64 |
totalElements |
Long |
int64 |
totalPages |
Long |
int64 |
number |
Long |
int64 |
13.93. Pageable
pageNumber |
Integer |
int32 |
unpaged |
Boolean |
pageSize |
Integer |
int32 |
paged |
Boolean |
sort |
Sort |
offset |
Long |
int64 |
13.94. PagedModelAttachment
links |
List of Link |
content |
List of Attachment |
page |
PageMetadata |
13.95. PagedModelAuditTrail
links |
List of Link |
content |
List of AuditTrail |
page |
PageMetadata |
13.96. PagedModelBackgroundSyncJobRepresentationModel
links |
List of Link |
content |
page |
PageMetadata |
13.97. PagedModelComment
links |
List of Link |
content |
List of Comment |
page |
PageMetadata |
13.98. PagedModelContextData
links |
List of Link |
content |
List of ContextData |
page |
PageMetadata |
13.99. PagedModelContextDataType
links |
List of Link |
content |
List of ContextDataType |
page |
PageMetadata |
13.100. PagedModelContextEvent
links |
List of Link |
content |
page |
PageMetadata |
13.101. PagedModelContextItem
links |
List of Link |
content |
List of ContextItem |
page |
PageMetadata |
13.102. PagedModelDataReference
links |
List of Link |
content |
List of DataReference |
page |
PageMetadata |
13.103. PagedModelExport
links |
List of Link |
content |
List of Export |
page |
PageMetadata |
13.104. PagedModelFailedEventFrameSynchronization
links |
List of Link |
content |
List of FailedEventFrameSynchronization |
page |
PageMetadata |
13.105. PagedModelField
links |
List of Link |
content |
List of Field |
page |
PageMetadata |
13.106. PagedModelKeyword
links |
List of Link |
content |
List of Keyword |
page |
PageMetadata |
13.107. PagedModelPropertyKeyMigrationFieldData
links |
List of Link |
content |
List of PropertyKeyMigrationFieldData |
page |
PageMetadata |
13.108. PagedModelPropertyKeyMigrationMonitorData
links |
List of Link |
content |
List of PropertyKeyMigrationMonitorData |
page |
PageMetadata |
13.109. PagedModelPropertyKeyMigrationViewData
links |
List of Link |
content |
List of PropertyKeyMigrationViewData |
page |
PageMetadata |
13.110. PagedModelSource
links |
List of Link |
content |
List of Source |
page |
PageMetadata |
13.111. PagedModelString
links |
List of Link |
content |
List of [string] |
page |
PageMetadata |
13.112. PagedModelTriggerDefinition
links |
List of Link |
content |
List of TriggerDefinition |
page |
PageMetadata |
13.113. PagedModelWorkflow
links |
List of Link |
content |
List of Workflow |
page |
PageMetadata |
13.114. Parameter
name |
String |
value |
String |
13.115. PeriodFilter
Represents a period filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
periodType |
String |
The period type |
Enum: ONE_HOUR, LAST_HOUR, TWO_HOURS, LAST_TWO_HOURS, EIGHT_HOURS, LAST_EIGHT_HOURS, ONE_DAY, LAST_DAY, SEVEN_DAYS, LAST_WEEK, LAST_FOUR_WEEKS, THIRTY_DAYS, INVALID, |
period |
String |
The period in String format |
ISO8601 |
live |
Boolean |
Indicates to start a live search |
13.116. PeriodFilterAllOf
periodType |
String |
The period type |
period |
String |
ISO8601 |
live |
Boolean |
13.117. PermissionUserDetails
Represents a subset of user details
userId |
String |
User's id. |
userName |
String |
User's username. |
firstName |
String |
User's first name. |
lastName |
String |
User's last name. |
admin |
Boolean |
Indication whether user is an admin or not. |
13.118. PropertyFieldFilter
Represents a String Field filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
fieldIdentifier |
UUID |
uuid |
field |
String |
key |
X |
String |
values |
X |
List of [string] |
13.119. PropertyFieldFilterAllOf
fieldIdentifier |
UUID |
uuid |
field |
String |
key |
String |
values |
List of [string] |
13.120. PropertyKeyMigrationField
original |
String |
migrated |
String |
13.121. PropertyKeyMigrationFieldData
Represents the changes to be performed on a field
identifier |
UUID |
uuid |
name |
String |
type |
String |
propertyKey |
String |
migratedKey |
String |
ambiguous |
Boolean |
createdByDetails |
UserDetails |
links |
List of Link |
13.122. PropertyKeyMigrationFieldFilter
original |
FieldFilter |
migrated |
FieldFilter |
13.123. PropertyKeyMigrationMonitorData
Represents the changes to be performed on a monitor
identifier |
UUID |
uuid |
monitorIdentifier |
String |
monitorOwner |
String |
monitorOwnerIdentifier |
String |
monitorName |
String |
monitorOwnerDetails |
UserDetails |
fields |
List of PropertyKeyMigrationField |
links |
List of Link |
13.124. PropertyKeyMigrationPhaseRepresentationModel
startDate |
Date |
date-time |
endDate |
Date |
date-time |
status |
String |
Enum: WAITING, RUNNING, FINISHED, FAILED, SKIPPED, |
13.125. PropertyKeyMigrationPhaseStatusModel
waitingForApproval |
String |
13.126. PropertyKeyMigrationPropertyFieldFilter
original |
PropertyFieldFilter |
migrated |
13.127. PropertyKeyMigrationStatusRepresentationModel
dryRun |
PropertyKeyMigrationPhaseRepresentationModel |
13.128. PropertyKeyMigrationViewData
Represents the changes to be performed on a view
identifier |
UUID |
uuid |
viewIdentifier |
String |
viewOwner |
String |
viewOwnerIdentifier |
String |
viewOwnerDetails |
UserDetails |
viewName |
String |
fieldFilters |
List of PropertyKeyMigrationFieldFilter |
propertyFilters |
ganttGroupBy |
ambiguous |
Boolean |
links |
List of Link |
13.129. ReactiveSearchRequestModel
Represents a reactive search request definition
filters |
sort |
Sort |
pageSize |
Integer |
int32 |
delay |
Integer |
int32 |
limit |
Integer |
int32 |
bufferSize |
Integer |
int32 |
useTimeSeriesIdentifier |
Boolean |
Boolean to indicate if Tag need to be resolved to UUIDs or not, default false |
dataSort |
Sort |
13.130. SearchParametersModel
Represents search parameters
query |
X |
String |
Search query |
hasPermission |
String |
includeDeleted |
Boolean |
page |
Integer |
int32 |
size |
Integer |
int32 |
sort |
List of [string] |
13.131. SearchRequestModel
filters |
13.132. Sort
unsorted |
Boolean |
sorted |
Boolean |
empty |
Boolean |
13.133. Source
identifier |
UUID |
The identifier of the source |
uuid |
name |
String |
The name of the source |
externalId |
String |
The identifier of the source in tm-datasource |
enabled |
Boolean |
Indication whether the LIVE synchronization for this source is enabled or not |
currentIntervalStart |
Date |
Lower end of the current interval being synced |
date-time |
currentIntervalEnd |
Date |
Upper end of the current interval being synced |
date-time |
currentIntervalCount |
Integer |
Number of items in the current interval being synced |
int32 |
currentIntervalPage |
Integer |
Current page of the current interval being synced |
int32 |
Date |
date-time |
exceptionMessage |
String |
syncPageSize |
Integer |
The sync page size |
int32 |
links |
List of Link |
13.134. SourceModel
The source to which this workflow belongs
identifier |
UUID |
The source's identifier. |
uuid |
enabled |
Boolean |
Indication whether live sync should be enabled or not. |
13.135. SourceSynchronizationIntervalModel
startDate |
X |
Date |
The start date of the interval to sync. |
date-time |
endDate |
Date |
The end date of the interval to sync. Current date will be taken if left empty. |
date-time |
cancelable |
Boolean |
13.136. StringFieldFilter
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
fieldIdentifier |
UUID |
uuid |
field |
String |
values |
List of [string] |
customField |
Field |
mode |
String |
13.137. StringFieldFilterAllOf
fieldIdentifier |
UUID |
uuid |
field |
String |
values |
List of [string] |
customField |
Field |
mode |
String |
13.138. TaskSubmissionResult
running |
Integer |
Number of tasks currently being executed. |
int32 |
queued |
Integer |
Number of tasks currently queued. |
int32 |
13.139. TimeSeriesDefinitionRepresentation
TimeSeries definition to which the data points. Can be empty, even if data is present.
datasourceId |
UUID |
uuid |
ownerId |
String |
externalId |
String |
name |
String |
description |
String |
type |
String |
units |
String |
interpolationType |
String |
deleted |
Boolean |
plotDataUrl |
String |
indexDataUrl |
String |
links |
List of Link |
id |
UUID |
uuid |
13.140. TokenMetaData
continuationToken |
String |
13.141. TokenizedPageModelContextItem
content |
page |
TokenMetaData |
13.142. TriggerDefinition
Represents a trigger definition
identifier |
String |
The identifier of the trigger |
state |
String |
The triggering state, an empty state means the trigger should fire on all possible states. |
type |
String |
The trigger type |
Enum: EXPORT_DASHBOARD, |
configuration |
Map of [string] |
The configuration for the trigger. Depends on the selected type |
links |
List of Link |
13.143. TriggerDefinitionModel
state |
String |
The workflow state causing this trigger to fire. An empty state means the trigger should fire on all possible states. |
type |
X |
String |
The trigger type. |
configuration |
X |
Map of [string] |
The configuration for the trigger. Depends on the selected type. |
13.144. TypeAccessRuleModel
Object used for creating and updating an access rule
identifier |
String |
The identifier of the access rule. |
subjectId |
X |
String |
subjectType |
X |
String |
The type of the subject. |
Enum: GUEST, EVERYONE, GROUP, USER, USER, GROUP, EVERYONE, GUEST, |
permissions |
X |
Set of [string] |
A set of permissions the subject has on the specified object. |
Enum: CONTEXT_TYPE_READ, CONTEXT_TYPE_WRITE, CONTEXT_TYPE_DELETE, |
13.145. TypeFilter
Represents a type filter definition
type |
String |
valid |
Boolean |
order |
Integer |
int32 |
types |
X |
List of [string] |
typeResources |
13.146. TypeFilterAllOf
types |
List of [string] |
typeResources |
13.147. UserDetails
The details of the user who created the context item
identifier |
String |
username |
String |
The name of the user who created the context item |
firstName |
String |
The first name of the user who created the context item |
lastName |
String |
The last name of the user who created the context item |
links |
List of Link |
13.148. ValidationResultMessage
key |
String |
message |
I18nMessage |
13.149. Workflow
Represents a work flow definition
identifier |
UUID |
The identifier of the workflow |
uuid |
name |
X |
String |
The name of the workflow |
startState |
X |
String |
The start state of the workflow |
endState |
X |
String |
The end state of the workflow |
states |
X |
Set of [string] |
The possible states of the workflow |
deletable |
Boolean |
Boolean that indicates if the workflow is deletable |
source |
Source |
links |
List of Link |
13.150. WorkflowModel
identifier |
UUID |
uuid |
source |
SourceModel |
externalId |
X |
String |
The identifier of the workflow in the external source system |
name |
X |
String |
startState |
X |
String |
endState |
X |
String |
states |
X |
Set of [string] |
deletable |
Boolean |
If the workflow is deletable or not |
13.151. WorkflowStates
Represents a work flow states definition
states |
X |
Set of [string] |
The possible states of the work flow |
links |
List of Link |
13.152. WorkflowStatesModel
Represents the possible states for a work flow definition
states |
X |
Set of [string] |
