Based on REST principles, the TrendMiner Compute API endpoints provide access to timeseries indexing functionality, timeseries analytics and timeseries index and plot optimized data.
1. Authentication
When performing actions authenticated as a client, they will belong to service-account-CLIENTID.
1.1. Creating a new client
Your client ID
curl --request POST \
200 OK
"expires_in": 300,
"refresh_expires_in": 0,
"token_type": "Bearer",
"scope": "email profile"
1.3. Doing a request with an access token
curl --request GET \
--url 'https://YOUR_DOMAIN/compute/[any api]' \
2. Resources
2.1. Calculations
2.1.1. Calculate the value of a tag on specific time ranges
POST /newCalculation
Parameters
Type |
Name |
Description |
Schema |
Body required |
CalculationRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
List[CalculationResult] |
400 |
Invalid request |
422 |
Unprocessable entity (e.g. index not found) |
Produces
application/json
2.1.2. Compare layers by a given algorithm
POST /newComparison
Parameters
Type |
Name |
Description |
Schema |
Body required |
ComparisonRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
List[ComparisonResult] |
400 |
Invalid request |
422 |
Unprocessable Entity (e.g. index does not exist) |
Produces
application/json
2.2. Charting
2.2.1. Check existence chart export
HEAD /charting/export/{id}/download
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
404 |
Chart export not found |
204 |
No Content |
401 |
Unauthorized |
2.2.2. Check if request exceeds maximum number of points
POST /charting/export/check-maximum-number-of-points
Parameters
Type |
Name |
Description |
Schema |
Body required |
ChartExportRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
CheckMaximumNumberOfPointsResult |
400 |
Invalid request |
422 |
Produces
2.2.3. Download chart export
GET /charting/export/{id}/download
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
404 |
204 |
No Content |
401 |
Unauthorized |
410 |
Chart export no longer exists |
2.2.4. Export focus chart data
Parameters
Type |
Name |
Description |
Schema |
Body required |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
202 |
Accepted |
400 |
Invalid request |
422 |
Produces
2.2.5. Generate plot data to display on the context chart
POST /newContextChart
Parameters
Type |
Name |
Description |
Schema |
Body required |
ChartRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
List[ContextChartResult] |
400 |
Invalid request |
Produces
application/json
2.2.6. Generate plot data to display on the focus chart
POST /newFocusChart
Parameters
Type |
Name |
Description |
Schema |
Body required |
ChartRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
List[ChartResult] |
400 |
Invalid request |
Produces
application/json
2.2.7. Generate histograms for the requested tags
POST /newHistogram
Parameters
Type |
Name |
Description |
Schema |
Body required |
HistogramRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
List[HistogramResultDTO] |
400 |
Invalid request |
422 |
Produces
application/json
2.2.8. Generate scatter plots for the each pair of requested tags
POST /scatterChart
Parameters
Type |
Name |
Description |
Schema |
Body required |
ScatterChartRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
List[ScatterChartResult] |
400 |
Invalid request |
422 |
Produces
application/json
2.2.9. Export focus chart data
POST /charting/legacy-export
Parameters
Type |
Name |
Description |
Schema |
Body required |
LegacyChartExportRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
400 |
Invalid request |
422 |
Produces
2.3. Data
2.3.1. Get index data
GET /data/index
Parameters
Type |
Name |
Description |
Schema |
Query required |
timeSeriesId |
Query required |
interpolationType |
Query required |
startDate |
Query required |
endDate |
Query required |
numberOfIntervals |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
OK |
List[WrappedDataPoints] |
Produces
application/stream+json
2.3.2. Get last value
GET /data/last-value
Parameters
Type |
Name |
Description |
Schema |
Query required |
timeSeriesId |
Query required |
interpolationType |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
OK |
LastValueModel |
422 |
LastValueModel |
Produces
application/json
2.3.3. Get interpolated data
POST /interpolatedData
Parameters
Type |
Name |
Description |
Schema |
Body required |
InterpolatedDataRequestAdapter |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
InterpolatedDataResult |
400 |
Invalid request |
422 |
MissingIndexDataBody |
Produces
application/json
2.3.4. Get paged interpolated data for some tag
POST /interpolatedData/paged
Parameters
Type |
Name |
Description |
Schema |
Body required |
PagedInterpolatedDataRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
InterpolatedDataPage |
400 |
Invalid request |
422 |
Produces
application/json
2.4. Indexing
2.4.1. Check if index needs repairing
POST /index/check
Parameters
| Type | Name | Description | Schema |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok. Index check started |
Produces
2.4.2. Delete index data by time series id
DELETE /index/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
String |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
Produces
2.4.3. Get paged overview of indexing processes
GET /index
Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
Query to filter results (RSQL syntax) |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Sorting criteria in the format: property(,asc |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
PagedModelIndexingDetailDTO |
Produces
application/json
application/hal+json
2.4.4. Get index details by time series id
GET /index/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
String |
Responses
HTTP Code |
Description |
Schema |
404 |
Index data for time series not found |
200 |
Ok |
IndexingDetailDTO |
Produces
application/json
2.4.5. Get last indexed point for a given time series
GET /index/{id}/last-indexed-point
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
404 |
Time series or index data not found |
200 |
Ok |
PointDTO |
Produces
2.4.6. Check if repair is running
GET /index/repair/status
Parameters
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
RepairIndexStatus |
Produces
2.4.7. Get repair index overview
GET /index/repair/progress
Parameters
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
RepairProgress |
Produces
2.4.8. Index a specific tag by time series id
POST /index/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
String |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok. Indexing started |
424 |
Index operation is not possible due to failed service dependencies |
Produces
2.4.9. Refresh index data by time series id
POST /index/{id}/refresh
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
String |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok. Refresh index started |
424 |
Produces
2.4.10. Repair index
POST /index/repair
Parameters
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok. Index repair started |
Produces
2.5. IndexingByName
2.5.1. Delete index data by tag name
DELETE /indexing/byName
Parameters
Type |
Name |
Description |
Schema |
Query required |
tagName |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok. Index deleted |
String |
Produces
2.5.2. Get indexed periods
GET /indexing/byName/periods
Parameters
Type |
Name |
Description |
Schema |
Query required |
tagNames |
Responses
HTTP Code |
Description |
Schema |
404 |
If a tag cannot be found or the user is not authorised |
200 |
Ok |
List[IndexingPeriodDTO] |
424 |
The DataSource service is not reachable |
Produces
2.5.3. Get indexing status by tag name
POST /indexing/byName/newStatus/
Parameters
Type |
Name |
Description |
Schema |
Body required |
IndexingStatusRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok. Indexing percentage |
IndexingPercentage |
424 |
DataSource not reachable |
Produces
application/json
2.5.4. Get indexing status by tag name
POST /indexing/byName/status/
Parameters
Type |
Name |
Description |
Schema |
Body required |
LegacyIndexingStatusRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok. Indexing status in legacy format |
LegacyIndexingStatusResponse |
424 |
Datasource not reachable |
Produces
application/json
2.5.5. Get search period
GET /indexing/byName/search-period
Parameters
Type |
Name |
Description |
Schema |
Query required |
tagNames |
Query required |
interpolationTypes |
Responses
HTTP Code |
Description |
Schema |
404 |
200 |
Ok |
SearchPeriod |
400 |
tag and interpolation types do not align |
424 |
Produces
2.5.6. Get simplified indexing status by tag name
Parameters
Type |
Name |
Description |
Schema |
Query required |
tagName |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
SimplifiedIndexingStatus |
Produces
application/json
2.5.7. Trigger indexing by tag name
Parameters
Type |
Name |
Description |
Schema |
Query required |
tagName |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
2.6. PublicDownloadGenerator
2.6.1. Generate
POST /download/generate
Parameters
Type |
Name |
Description |
Schema |
Body required |
LinkModel |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
DataModel |
Produces
application/json
2.7. Searches
2.7.1. Download search request export
GET /search-requests/{searchRequestId}/export/{exportId}/download
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
UUID |
Path required |
exportId |
UUID |
Responses
HTTP Code |
Description |
Schema |
404 |
Search request export not found |
200 |
OK |
401 |
Unauthorized |
410 |
Search request export no longer exists |
2.7.2. Export results of search request
POST /search-requests/{searchRequestId}/export
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
UUID |
Body required |
SearchRequestExportRequestModel |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
202 |
Accepted |
400 |
Invalid request |
Produces
2.7.3. Export search results
POST /searches/results/export
Parameters
Type |
Name |
Description |
Schema |
Body required |
SearchExportRequestModel |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
400 |
Invalid request |
Produces
2.7.4. Get search request binning/sorting options
GET /search-requests/{searchRequestId}/binningOptions
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
UUID |
Query optional |
clientTimeZone |
Responses
HTTP Code |
Description |
Schema |
404 |
Search request does not exist |
200 |
Ok |
BinningAndSortingOptionsDTO |
400 |
Invalid request |
Produces
application/json
2.7.5. Get bins for a search request
GET /search-requests/{searchRequestId}/bins
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
The id of the search request |
UUID |
Query required |
binBy |
The type of bins to retrieve for the search. Supported binning types: DATE DURATION |
Query optional |
lowerBound |
The lower bound for the bin type for which to generate bins |
Query optional |
upperBound |
The upper bound for the bin type for which to generate bins |
Query optional |
sort |
Sorting criteria in the format: binType(,asc |
desc). Default sort ordering depends on the bin type binType needs to be equivalent to the defined binBy parameter |
Query optional |
clientTimeZone |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
BinsDTO |
Produces
application/json
2.7.6. Get search request
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
UUID |
Query optional |
clientTimeZone |
Responses
HTTP Code |
Description |
Schema |
404 |
Search request not found |
200 |
Ok |
SearchRequestDTO |
400 |
Invalid request |
Produces
application/json
2.7.7. Get search results
GET /search-requests/{searchRequestId}/results
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
UUID |
Query required |
binBy |
Query optional |
lowerBound |
Query optional |
upperBound |
Query optional |
clientTimeZone |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
PagedModelSearchResultDTO |
Produces
application/json
2.7.8. Highlight search request
POST /search-requests/{searchRequestId}/highlights
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
UUID |
Body required |
SearchRequestHighlightRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
202 |
Accepted |
List[SearchRequestHighlight] |
400 |
Invalid request |
Produces
2.7.9. Refinement search request
POST /search-requests/{searchRequestId}/refinementOptions
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
UUID |
Body optional |
SearchRequestRefinementRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
202 |
Accepted |
List[RefinementOption] |
400 |
Invalid request |
Produces
2.7.10. Retrieve refinements for a search request
GET /search-requests/{searchRequestId}/refinements
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
UUID |
Responses
HTTP Code |
Description |
Schema |
404 |
200 |
Ok |
List[Refinement] |
Produces
2.7.11. Perform an area search search
POST /areasearch/newSearch
Parameters
Type |
Name |
Description |
Schema |
Body required |
AreaSearchRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
List[DeprecatedSearchResult] |
400 |
Invalid request |
422 |
Produces
application/json
2.7.12. Perform a context item search
POST /contextitemsearch/search
Parameters
Type |
Name |
Description |
Schema |
Body required |
ContextItemSearchRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
400 |
Invalid request |
Produces
application/json
2.7.13. Detect fingerprint deviations (with early warning support)
POST /fingerprintsearch/earlywarning
Parameters
Type |
Name |
Description |
Schema |
Body required |
FingerprintEarlyWarningRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
EarlyWarningResult |
400 |
Invalid request |
422 |
Produces
application/json
2.7.14. Perform a fingerprint search
POST /fingerprintsearch/newSearch
Parameters
Type |
Name |
Description |
Schema |
Body required |
FingerprintSearchRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
List[SimilaritySearchResult] |
400 |
Invalid request |
422 |
Produces
application/json
2.7.15. Perform a similarity search
POST /similaritysearch/newSearch
Parameters
Type |
Name |
Description |
Schema |
Body required |
SimilaritySearchRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
400 |
Invalid request |
422 |
Produces
application/json
2.7.16. Perform a step search
POST /stepsearch/newSearch
Parameters
Type |
Name |
Description |
Schema |
Body required |
StepSearchRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
400 |
Invalid request |
422 |
Produces
application/json
2.7.17. Perform a value-based search
POST /valuebasedsearch/newSearch
Parameters
Type |
Name |
Description |
Schema |
Body required |
ValueBasedSearchRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
400 |
Invalid request |
422 |
Produces
application/json
2.7.18. Search on index data
POST /search
Parameters
Type |
Name |
Description |
Schema |
Body required |
SearchRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Tag not found |
200 |
Ok |
List[SearchResult] |
400 |
Invalid request |
422 |
Produces
application/json
2.7.19. Search on index data
Parameters
Type |
Name |
Description |
Schema |
Query optional |
clientTimeZone |
Body required |
SearchRequest |
Responses
HTTP Code |
Description |
Schema |
404 |
Not Found |
String |
200 |
Ok |
SearchRequestDTO |
400 |
Invalid request |
422 |
Produces
application/json
2.7.20. Check existence search request export
HEAD /search-requests/{searchRequestId}/export/{exportId}/download
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
UUID |
Path required |
exportId |
UUID |
Responses
HTTP Code |
Description |
Schema |
404 |
204 |
No Content |
401 |
Unauthorized |
2.7.21. Update and trigger calculations
POST /search-requests/{searchRequestId}/calculations
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
UUID |
Query optional |
clientTimeZone |
Body required |
CalculationDefinition |
Responses
HTTP Code |
Description |
Schema |
404 |
200 |
Ok |
SearchRequestDTO |
400 |
Invalid request |
409 |
Search request is already in progress |
412 |
Search request detected an error |
Produces
application/json
2.7.22. Update refinements request
PUT /search-requests/{searchRequestId}/refinements
Parameters
Type |
Name |
Description |
Schema |
Path required |
searchRequestId |
UUID |
Body required |
Responses
HTTP Code |
Description |
Schema |
404 |
202 |
Accepted |
List[Refinement] |
400 |
Invalid request |
Produces
3. Models
3.1. AbstractSearchWarningDto
| Field Name | Required | Type | Description | Format |
details |
Map of [object] |
message |
String |
errorCode |
String |
3.2. AreaSearchDefinition
type |
String |
Enum: SIMILARITY_SEARCH, VALUE_BASED_SEARCH, AREA_SEARCH, STEP_SEARCH, CONTEXT_ITEM_SEARCH, |
calculations |
List of CalculationDefinition |
queries |
List of AreaSearchQuery |
parameters |
AreaSearchParameters |
3.3. AreaSearchDefinitionAllOf
queries |
parameters |
3.4. AreaSearchDetails
name |
String |
description |
String |
type |
String |
searchPeriod |
SearchPeriod |
minimumIntervalLength |
Long |
int64 |
isInExtent |
Boolean |
xTag |
AxisTag |
yTag |
AxisTag |
3.5. AreaSearchDetailsAllOf
Long |
int64 |
isInExtent |
Boolean |
xTag |
AxisTag |
yTag |
AxisTag |
3.6. AreaSearchParameters
minimumDuration |
Long |
int64 |
searchType |
String |
Enum: INSIDE_AREA, OUTSIDE_AREA, |
searchArea |
List of PointCoordinate |
3.7. AreaSearchQuery
xAxis |
TimeSeriesDescriptor |
yAxis |
3.8. AreaSearchRequest
contextTimeRange |
TimePeriod |
filters |
List of FilterTimePeriod |
query |
DeprecatedAreaSearchQuery |
params |
DeprecatedAreaSearchParameters |
3.9. AxisTag
name |
String |
3.10. BinDTO
id |
String |
upperBound |
String |
lowerBound |
String |
type |
String |
size |
Integer |
int32 |
links |
List of Link |
3.11. BinningAndSortingOptionsDTO
options |
List of BinningOptionDTO |
calculations |
default |
SortingOptionDTO |
3.12. BinningOptionDTO
option |
String |
links |
List of Link |
sortKey |
String |
3.13. BinsDTO
bins |
List of BinDTO |
size |
Integer |
int32 |
links |
List of Link |
3.14. BucketDTO
min |
Float |
float |
max |
Float |
float |
totalNumberOfResults |
Integer |
int32 |
refinedNumberOfResults |
Integer |
int32 |
3.15. CalculationDefinition
name |
String |
type |
String |
Enum: MIN, MAX, MEAN, RANGE, START, END, DELTA, INTEGRAL, STDEV, |
unit |
String |
reference |
3.16. CalculationParameters
calculationType |
String |
3.17. CalculationQuery
tag |
TagDescriptorDTO |
timePeriods |
List of CalculationTimePeriod |
3.18. CalculationRequest
queries |
CalculationQuery |
parameters |
CalculationParameters |
3.19. CalculationResult
startDate |
Date |
date-time |
endDate |
Date |
date-time |
value |
Float |
float |
key |
String |
3.20. CalculationTimePeriod
startDate |
Date |
date-time |
endDate |
Date |
date-time |
key |
String |
3.21. CalculationToExport
name |
String |
tagName |
String |
unit |
String |
operator |
String |
3.22. ChartExportRequest
layers |
List of Layer |
filterTimePeriods |
List of TimePeriod |
chartDataResolutionInSeconds |
Integer |
int32 |
clientTimeZoneId |
String |
excludeFilteredTimePeriods |
Boolean |
viewName |
String |
downloadName |
String |
fileType |
String |
Enum: XLSX, |
exportType |
String |
Enum: FOCUS_CHART, SEARCH_RESULT, |
downloadLink |
String |
3.23. ChartRequest
timePeriod |
TimePeriod |
queries |
List of TagDescriptorDTO |
parameters |
ChartRequestParameters |
3.24. ChartRequestParameters
numberOfIntervals |
Integer |
int32 |
3.25. ChartResult
tag |
TagDescriptorDTO |
values |
List of PointDTO |
error |
String |
errorCode |
String |
Enum: OUT_OF_ORDER, ONLY_RAW_VALUES_SUPPORTED, TIMEOUT, REMOTE_SERVICE, SERVICE_UNAVAILABLE, UNEXPECTED, VALIDATION_FAILED, PARSE_FAILED, NOT_ALLOWED, NOT_FOUND, TOO_MANY_REQUESTS, FAILED_DEPENDENCY, PLOT_PERIOD_TOO_LARGE, MISSING_INDEX_DATA, |
3.26. CheckMaximumNumberOfPointsResult
requestExceedsMaximumNumberOfPoints |
Boolean |
maximumNumberOfPoints |
Long |
int64 |
3.27. ComparisonLayerResult
startDate |
Date |
date-time |
endDate |
Date |
date-time |
key |
String |
value |
Float |
float |
differenceToBase |
Float |
float |
3.28. ComparisonRequest
query |
ComparisonRequestQuery |
params |
ComparisonRequestParams |
filters |
3.29. ComparisonRequestParams
comparisonType |
String |
Enum: MIN, MAX, MEAN, RANGE, START, END, DELTA, INTEGRAL, STDEV, CORRELATION, EVOLUTION, STATISTICAL_SIMILARITY, |
3.30. ComparisonRequestQuery
tag |
referenceLayer |
compareLayers |
3.31. ComparisonResult
tag |
TagDescriptorDTO |
referenceLayerResult |
CalculationResult |
compareLayerResults |
List of ComparisonLayerResult |
3.32. ContextChartResult
tag |
TagDescriptorDTO |
values |
List of PointDTO |
isFullyIndexed |
Boolean |
3.33. ContextItemSearchDefinition
type |
String |
calculations |
queries |
List of [map] |
3.34. ContextItemSearchDetails
name |
String |
description |
String |
type |
String |
searchPeriod |
SearchPeriod |
queries |
List of [map] |
3.35. ContextItemSearchDetailsAllOf
queries |
List of [map] |
3.36. ContextItemSearchRequest
contextTimeRange |
TimePeriod |
filters |
queries |
List of [map] |
3.37. CrossAssetValueBasedSearchDetails
name |
String |
description |
String |
type |
String |
searchPeriod |
SearchPeriod |
contextTimeRange |
TimePeriod |
filters |
queries |
List of CrossAssetValueBasedSearchQuery |
params |
CrossAssetValueBasedSearchParameters |
requestId |
UUID |
uuid |
3.38. CrossAssetValueBasedSearchDetailsAllOf
contextTimeRange |
TimePeriod |
filters |
queries |
params |
requestId |
UUID |
uuid |
3.39. CrossAssetValueBasedSearchParameters
assets |
List of DataReference |
Long |
int64 |
operator |
String |
3.40. CrossAssetValueBasedSearchQuery
attributeTemplateId |
String |
operator |
String |
values |
List of [float] |
float |
3.41. DataModel
data |
String |
the signed link data |
3.42. DataPoint
ts |
Date |
date-time |
value |
Float |
float |
3.43. DataReference
id |
String |
name |
String |
type |
String |
Enum: ASSET, ATTRIBUTE, TAG, |
3.44. DataReferenceDescriptor
id |
String |
name |
String |
type |
String |
shift |
Long |
int64 |
interpolationType |
String |
3.45. DeprecatedAreaPoint
x |
Float |
float |
y |
Float |
float |
3.46. DeprecatedAreaSearchParameters
searchArea |
List of DeprecatedAreaPoint |
searchType |
String |
Long |
int64 |
3.47. DeprecatedAreaSearchQuery
xAxisTag |
TagDescriptorDTO |
yAxisTag |
TagDescriptorDTO |
3.48. DeprecatedSearchResult
startDate |
Date |
date-time |
endDate |
Date |
date-time |
openEnded |
Boolean |
3.49. DeprecatedSimilaritySearchParameters
focusTimePeriod |
TimePeriod |
detectionThreshold |
Float |
float |
limitResults |
Integer |
int32 |
3.50. DeprecatedSimilaritySearchQuery
patternTag |
TagDescriptorDTO |
searchInTag |
TagDescriptorDTO |
searchType |
String |
Enum: ABSOLUTE_VALUES, FINGERPRINT, SIGNAL_SHAPE, |
range |
SimilaritySearchRange |
weights |
List of DeprecatedSimilaritySearchWeight |
3.51. DeprecatedSimilaritySearchWeight
weight |
Float |
float |
start |
Date |
date-time |
end |
Date |
date-time |
3.52. DeprecatedStepSearchQuery
tagDescriptor |
TagDescriptorDTO |
from |
StepSearchCondition |
to |
3.53. DeprecatedValueBasedSearchParameters
minIntervalInSeconds |
Long |
int64 |
searchOperator |
String |
Enum: AND, OR, |
3.54. DeprecatedValueBasedSearchQuery
tagDescriptor |
TagDescriptorDTO |
conditionOperator |
String |
Enum: LESS_THAN, LESS_THAN_OR_EQUAL, EQUAL, NOT_EQUAL, GREATER_THAN_OR_EQUAL, GREATER_THAN, CONSTANT, INSET, |
values |
List of [float] |
float |
3.55. EarlyWarningResult
partial |
Boolean |
mismatch |
Boolean |
score |
Float |
float |
3.56. ErrorResponse
timestamp |
Date |
date-time |
errorCode |
String |
Enum: OUT_OF_ORDER, ONLY_RAW_VALUES_SUPPORTED, TIMEOUT, REMOTE_SERVICE, SERVICE_UNAVAILABLE, UNEXPECTED, VALIDATION_FAILED, PARSE_FAILED, INVALID_DUPLICATE_POINT, NOT_ALLOWED, NOT_FOUND, TOO_MANY_REQUESTS, PLOT_PERIOD_TOO_LARGE, MISSING_INDEX_DATA, |
message |
String |
details |
Map of [string] |
httpStatus |
String |
Enum: 100 CONTINUE, 101 SWITCHING_PROTOCOLS, 102 PROCESSING, 103 CHECKPOINT, 200 OK, 201 CREATED, 202 ACCEPTED, 203 NON_AUTHORITATIVE_INFORMATION, 204 NO_CONTENT, 205 RESET_CONTENT, 206 PARTIAL_CONTENT, 207 MULTI_STATUS, 208 ALREADY_REPORTED, 226 IM_USED, 300 MULTIPLE_CHOICES, 301 MOVED_PERMANENTLY, 302 FOUND, 302 MOVED_TEMPORARILY, 303 SEE_OTHER, 304 NOT_MODIFIED, 305 USE_PROXY, 307 TEMPORARY_REDIRECT, 308 PERMANENT_REDIRECT, 400 BAD_REQUEST, 401 UNAUTHORIZED, 402 PAYMENT_REQUIRED, 403 FORBIDDEN, 404 NOT_FOUND, 405 METHOD_NOT_ALLOWED, 406 NOT_ACCEPTABLE, 407 PROXY_AUTHENTICATION_REQUIRED, 408 REQUEST_TIMEOUT, 409 CONFLICT, 410 GONE, 411 LENGTH_REQUIRED, 412 PRECONDITION_FAILED, 413 PAYLOAD_TOO_LARGE, 413 REQUEST_ENTITY_TOO_LARGE, 414 URI_TOO_LONG, 414 REQUEST_URI_TOO_LONG, 415 UNSUPPORTED_MEDIA_TYPE, 416 REQUESTED_RANGE_NOT_SATISFIABLE, 417 EXPECTATION_FAILED, 418 I_AM_A_TEAPOT, 419 INSUFFICIENT_SPACE_ON_RESOURCE, 420 METHOD_FAILURE, 421 DESTINATION_LOCKED, 422 UNPROCESSABLE_ENTITY, 423 LOCKED, 424 FAILED_DEPENDENCY, 425 TOO_EARLY, 426 UPGRADE_REQUIRED, 428 PRECONDITION_REQUIRED, 429 TOO_MANY_REQUESTS, 431 REQUEST_HEADER_FIELDS_TOO_LARGE, 451 UNAVAILABLE_FOR_LEGAL_REASONS, 500 INTERNAL_SERVER_ERROR, 501 NOT_IMPLEMENTED, 502 BAD_GATEWAY, 503 SERVICE_UNAVAILABLE, 504 GATEWAY_TIMEOUT, 505 HTTP_VERSION_NOT_SUPPORTED, 506 VARIANT_ALSO_NEGOTIATES, 507 INSUFFICIENT_STORAGE, 508 LOOP_DETECTED, 509 BANDWIDTH_LIMIT_EXCEEDED, 510 NOT_EXTENDED, 511 NETWORK_AUTHENTICATION_REQUIRED, |
statusCode |
Integer |
int32 |
3.57. ExportSimilaritySearchQuery
name |
String |
shift |
Long |
int64 |
searchIn |
SimilaritySearchQuerySearchIn |
searchType |
String |
weights |
List of SimilaritySearchWeight |
3.58. ExportValueBasedSearchQuery
operator |
String |
shift |
Long |
int64 |
tagName |
String |
value |
List of [string] |
3.59. FilterTimePeriod
startDate |
Date |
date-time |
endDate |
Date |
date-time |
type |
String |
Enum: EXCLUDE, INCLUDE, |
3.60. FingerprintEarlyWarningRequest
contextTimePeriod |
TimePeriod |
params |
FingerprintSearchParameters |
queries |
List of FingerprintSearchQuery |
3.61. FingerprintSearchParameters
Float |
float |
duration |
Long |
int64 |
3.62. FingerprintSearchQuery
tag |
TagDescriptorDTO |
hulls |
List of HullValue |
3.63. FingerprintSearchRequest
contextTimePeriod |
TimePeriod |
filters |
params |
queries |
3.64. FocusChartTag
tagName |
String |
shift |
Integer |
int32 |
interpolationType |
String |
3.65. HistogramQueryDTO
tag |
TagDescriptorDTO |
scale |
Scale |
3.66. HistogramRequest
timePeriod |
TimePeriod |
queries |
List of HistogramQueryDTO |
filters |
3.67. HistogramResultDTO
query |
HistogramQueryDTO |
values |
List of HistogramValue |
3.68. HistogramValue
frequency |
Integer |
int32 |
value |
Float |
float |
3.69. HullValue
minValue |
X |
Float |
float |
maxValue |
X |
Float |
float |
offset |
X |
Long |
int64 |
3.70. IndexingDetailDTO
id |
String |
name |
String |
status |
String |
startDate |
Date |
date-time |
endDate |
Date |
date-time |
lastUpdatedDate |
Date |
date-time |
indexingProgress |
Float |
float |
links |
List of Link |
3.71. IndexingPercentage
percentage |
Float |
float |
3.72. IndexingPeriodDTO
tagName |
String |
startDate |
Date |
date-time |
endDate |
Date |
date-time |
indexed |
Boolean |
3.73. IndexingStatusQuery
tag |
TagDescriptorDTO |
3.74. IndexingStatusRequest
query |
IndexingStatusQuery |
3.75. InterpolatedDataPage
tag |
TagDescriptorDTO |
values |
List of PointDTO |
nextStartDate |
Date |
date-time |
3.76. InterpolatedDataRequestAdapter
tag |
TagDescriptorDTO |
timePeriod |
TimePeriod |
step |
Integer |
int32 |
3.77. InterpolatedDataResult
tag |
TagDescriptorDTO |
values |
List of PointDTO |
3.78. LastValueModel
value |
Float |
float |
ts |
Date |
date-time |
upToDate |
Boolean |
3.79. Layer
name |
String |
dataReferences |
List of DataReferenceDescriptor |
timePeriod |
TimePeriod |
3.80. LegacyChartExportRequest
tags |
List of [array] |
timePeriods |
filterPeriods |
multipleOfIndexBlockSize |
Integer |
int32 |
clientTimeZoneId |
String |
viewName |
String |
3.81. LegacyIndexingStatusRequest
name |
String |
shift |
Long |
int64 |
interpolationType |
String |
3.82. LegacyIndexingStatusResponse
allowSearch |
Boolean |
indexed |
Boolean |
percentage |
Float |
float |
3.83. Link
rel |
String |
href |
String |
hreflang |
String |
media |
String |
title |
String |
type |
String |
deprecation |
String |
profile |
String |
name |
String |
3.84. LinkModel
link |
X |
String |
The requested link. |
validity |
Long |
int64 |
3.85. MissingIndexDataBody
message |
String |
path |
String |
status |
Integer |
int32 |
error |
String |
errorCode |
String |
timestamp |
String |
3.86. PageMetadata
size |
Long |
int64 |
totalElements |
Long |
int64 |
totalPages |
Long |
int64 |
number |
Long |
int64 |
3.87. PagedInterpolatedDataRequest
tag |
TagDescriptorDTO |
timePeriod |
TimePeriod |
step |
Integer |
int32 |
3.88. PagedModelIndexingDetailDTO
links |
List of Link |
content |
List of IndexingDetailDTO |
page |
PageMetadata |
3.89. PagedModelSearchResultDTO
links |
List of Link |
content |
List of SearchResultDTO |
page |
PageMetadata |
3.90. PointCoordinate
x |
Float |
float |
y |
Float |
float |
3.91. PointDTO
ts |
Date |
date-time |
value |
Float |
float |
3.92. Refinement
option |
String |
min |
Float |
float |
max |
Float |
float |
3.93. RefinementOption
start |
String |
min |
Float |
float |
max |
Float |
float |
buckets |
List of BucketDTO |
option |
String |
3.94. RepairIndexStatus
running |
Boolean |
3.95. RepairProgress
totalNumberOfTags |
Integer |
int32 |
totalCheckedTags |
Integer |
int32 |
totalCorruptTags |
Integer |
int32 |
corruptedTags |
Map of [DateTime] |
date-time |
failedTags |
Map of [string] |
3.96. Scale
min |
Float |
float |
max |
Float |
float |
3.97. ScatterChartPoint
x |
Float |
float |
y |
Float |
float |
ts |
Date |
date-time |
3.98. ScatterChartRequest
timePeriod |
TimePeriod |
queries |
params |
Integer |
int32 |
filters |
3.99. ScatterChartResult
tagX |
TagDescriptorDTO |
tagY |
TagDescriptorDTO |
values |
List of ScatterChartPoint |
3.100. SearchDefinition
type |
String |
calculations |
3.101. SearchDetails
name |
String |
description |
String |
type |
String |
searchPeriod |
SearchPeriod |
3.102. SearchDetailsModel
name |
String |
description |
String |
3.103. SearchExportRequestModel
searchDetails |
oneOf<AreaSearchDetails,ContextItemSearchDetails,CrossAssetValueBasedSearchDetails,SimilaritySearchDetails,StepSearchDetails,ValueBasedSearchDetails> |
results |
List of SearchResultToExportModel |
calculation |
CalculationToExport |
clientTimeZoneId |
String |
3.104. SearchPeriod
startDate |
Date |
date-time |
endDate |
Date |
date-time |
3.105. SearchRequest
contextTimePeriod |
TimePeriod |
exclusionPeriods |
definition |
X |
oneOf<AreaSearchDefinition,ContextItemSearchDefinition,SimilaritySearchDefinition,StepSearchDefinition,ValueBasedSearchDefinition> |
3.106. SearchRequestDTO
id |
UUID |
uuid |
createdAt |
Date |
date-time |
status |
String |
Enum: IN_PROGRESS, DONE, ERROR, |
completedAt |
Date |
date-time |
errorCode |
String |
warnings |
List of AbstractSearchWarningDto |
refined |
Boolean |
links |
List of Link |
3.107. SearchRequestExportRequestModel
searchDetails |
SearchDetailsModel |
clientTimeZone |
String |
resultType |
String |
Enum: SEARCH_RESULT, BIN, |
results |
List of [string] |
sort |
Sort |
3.108. SearchRequestHighlight
start |
Date |
date-time |
end |
Date |
date-time |
3.109. SearchRequestHighlightRequest
contextTimePeriod |
TimePeriod |
maximumDistinguishablePeriods |
Integer |
int32 |
3.110. SearchRequestRefinementRequest
refinements |
List of Refinement |
3.111. SearchResult
id |
UUID |
uuid |
start |
Date |
date-time |
end |
Date |
date-time |
calculations |
Map of [object] |
properties |
Map of [object] |
duration |
Long |
int64 |
3.112. SearchResultDTO
id |
UUID |
uuid |
type |
String |
start |
Date |
date-time |
end |
Date |
date-time |
duration |
Integer |
int32 |
calculations |
Map of [object] |
properties |
Map of [object] |
links |
List of Link |
3.113. SearchResultToExportModel
start |
Date |
date-time |
end |
Date |
date-time |
dataReference |
String |
calc |
String |
score |
Float |
float |
3.114. SimilaritySearchDefinition
type |
String |
calculations |
queries |
List of SimilaritySearchQuery |
parameters |
SimilaritySearchParameters |
3.115. SimilaritySearchDefinitionAllOf
queries |
parameters |
3.116. SimilaritySearchDetails
name |
String |
description |
String |
type |
String |
searchPeriod |
SearchPeriod |
originalStartDate |
Date |
date-time |
originalEndDate |
Date |
date-time |
cutOffPercentage |
Float |
float |
tags |
List of ExportSimilaritySearchQuery |
3.117. SimilaritySearchDetailsAllOf
originalStartDate |
Date |
date-time |
originalEndDate |
Date |
date-time |
cutOffPercentage |
Float |
float |
tags |
3.118. SimilaritySearchParameters
focusTimePeriod |
TimePeriod |
Float |
float |
3.119. SimilaritySearchQuery
source |
target |
searchType |
String |
range |
SimilaritySearchQueryRange |
weights |
List of SimilaritySearchQueryWeight |
3.120. SimilaritySearchQueryRange
min |
Float |
float |
max |
Float |
float |
3.121. SimilaritySearchQuerySearchIn
tagName |
String |
3.122. SimilaritySearchQueryWeight
weight |
Float |
float |
start |
Date |
date-time |
end |
Date |
date-time |
3.123. SimilaritySearchRange
min |
Float |
float |
max |
Float |
float |
3.124. SimilaritySearchRequest
contextTimePeriod |
TimePeriod |
filters |
queries |
List of DeprecatedSimilaritySearchQuery |
params |
DeprecatedSimilaritySearchParameters |
3.125. SimilaritySearchResult
startDate |
Date |
date-time |
endDate |
Date |
date-time |
openEnded |
Boolean |
score |
Float |
float |
3.126. SimilaritySearchWeight
weight |
Integer |
int32 |
startDate |
Date |
date-time |
endDate |
Date |
date-time |
3.127. SimplifiedIndexingStatus
indexed |
Boolean |
3.128. Sort
sortKey |
String |
direction |
String |
3.129. SortingOptionDTO
binningOption |
BinningOptionDTO |
sort |
String |
3.130. StepSearchCondition
state |
Float |
float |
duration |
Integer |
int32 |
3.131. StepSearchDefinition
type |
String |
calculations |
queries |
List of StepSearchQuery |
3.132. StepSearchDefinitionAllOf
queries |
3.133. StepSearchDetails
name |
String |
description |
String |
type |
String |
searchPeriod |
SearchPeriod |
tagName |
String |
stateFrom |
StepSearchStateModel |
stateTo |
durationFrom |
Integer |
int32 |
durationTo |
Integer |
int32 |
shift |
Long |
int64 |
3.134. StepSearchDetailsAllOf
tagName |
String |
stateFrom |
stateTo |
durationFrom |
Integer |
int32 |
durationTo |
Integer |
int32 |
shift |
Long |
int64 |
3.135. StepSearchQuery
reference |
from |
StepSearchQueryCondition |
to |
3.136. StepSearchQueryCondition
state |
Integer |
int32 |
duration |
Long |
int64 |
3.137. StepSearchRequest
contextTimeRange |
TimePeriod |
filters |
query |
DeprecatedStepSearchQuery |
3.138. StepSearchStateModel
name |
String |
3.139. TagDescriptorDTO
id |
String |
shift |
Long |
int64 |
interpolationType |
String |
3.140. TimePeriod
startDate |
Date |
date-time |
endDate |
Date |
date-time |
3.141. TimeSeriesDescriptor
id |
String |
name |
String |
interpolationType |
String |
Enum: LINEAR, STEPPED, |
shift |
Long |
int64 |
3.142. ValueBasedSearchDefinition
type |
String |
calculations |
queries |
List of ValueBasedSearchQuery |
parameters |
3.143. ValueBasedSearchDefinitionAllOf
queries |
parameters |
3.144. ValueBasedSearchDetails
name |
String |
description |
String |
type |
String |
searchPeriod |
SearchPeriod |
String |
operator |
String |
queries |
List of ExportValueBasedSearchQuery |
3.145. ValueBasedSearchDetailsAllOf
String |
operator |
String |
queries |
3.146. ValueBasedSearchParameters
minimumDuration |
Long |
int64 |
operator |
String |
Enum: AND, OR, |
3.147. ValueBasedSearchQuery
values |
List of [float] |
float |
reference |
condition |
String |
3.148. ValueBasedSearchRequest
contextTimeRange |
TimePeriod |
filters |
queries |
List of DeprecatedValueBasedSearchQuery |
params |
DeprecatedValueBasedSearchParameters |
3.149. WrappedDataPoints
points |
List of DataPoint |
error |
ErrorResponse |
